Hi, I’m using ParaView 5.8.0 and 5.6.2 on Windows 10. I am making Python scripts to run on the ParaView Python Shell (which I want to be able to run with both versions 5.8 and 5.6) and I ran into an issue with compatibility of the Show( ) function between versions.
The issue is with the number of input arguments to Show( ). I was originally running the scripts on 5.8 and Show( ) had three arguments; here is an example of a line in a script I was running:
surfaceVectors1Display = Show(surfaceVectors1, renderView1, 'UnstructuredGridRepresentation')
When running the script in version 5.6.2, I got an error saying that there shouldn’t be more than two input arguments. So, I removed the ‘UnstructuredGridRepresentation’ argument and it ran fine without errors in both version 5.6 and 5.8. My question is: is it safe to remove that third argument? The decision to remove it was fairly arbitrary and was only because version 5.6 could not handle 3 arguments. There was seemingly no difference in the results of the script when I removed the third argument so does it actually have any importance? Why does this argument work in version 5.8 but not 5.6?
