i’m trying to visualize my finite-elements-analysis in paraview.
I have an .pvd-File like this:
<?xml version="1.0"?>
<VTKFile type="Collection" version="1.0" byte_order="LittleEndian" header_type="UInt64">
<Collection>
<DataSet timestep="0.0" part="0" file="myvtmFile_Step1_Frame0.vtm"/>
<DataSet timestep="0.05" part="0" file="myvtmFile_Step1_Frame1.vtm"/>
<DataSet timestep="0.1" part="0" file="myvtmFile_Step1_Frame2.vtm"/>
<DataSet timestep="0.15" part="0" file="myvtmFile_Step1_Frame3.vtm"/>
<DataSet timestep="0.2" part="0" file="myvtmFile_Step1_Frame4.vtm"/>
<DataSet timestep="0.25" part="0" file="myvtmFile_Step1_Frame5.vtm"/>
<DataSet timestep="0.325" part="0" file="myvtmFile_Step1_Frame6.vtm"/>
<DataSet timestep="0.425" part="0" file="myvtmFile_Step1_Frame7.vtm"/>
<DataSet timestep="0.525" part="0" file="myvtmFile_Step1_Frame8.vtm"/>
<DataSet timestep="0.625" part="0" file="myvtmFile_Step1_Frame9.vtm"/>
<DataSet timestep="0.725" part="0" file="myvtmFile_Step1_Frame10.vtm"/>
<DataSet timestep="0.825" part="0" file="myvtmFile_Step1_Frame11.vtm"/>
<DataSet timestep="0.925" part="0" file="myvtmFile_Step1_Frame12.vtm"/>
<DataSet timestep="1.0" part="0" file="myvtmFile_Frame13.vtm"/>
<DataSet timestep="1.000001" part="0" file="myvtmFile_Step2_Frame0.vtm"/>
<DataSet timestep="1.25" part="0" file="myvtmFile_Step2_Frame1.vtm"/>
<DataSet timestep="1.5" part="0" file="myvtmFile_Step2_Frame2.vtm"/>
<DataSet timestep="1.75" part="0" file="myvtmFile_Step2_Frame3.vtm"/>
<DataSet timestep="2.0" part="0" file="myvtmFile_Step2_Frame4.vtm"/>
</Collection>
</VTKFile>
is it possible to annotate a text in paraview depending on the timestep? for example i would like to show a text annotation which checks the current displayed timestep in paraview and then decides which text is shown.
Desired Output:
If current timestep shown in paraview is between 0.0 and 1.0 ==> show a text annotation “Step-1”
If current timestep shown in paraview is greater than 1.0 ==> show a text annotation “Step-2”
thanks in advance
