Hi
I have a contour plot and i have turned on axes grid around my contour. But it is showing the axes on both top and bottom. Can i only show the bottom axes and the ticks on it?
Chart views have an advanced property named Show Top Axis Grid that you can uncheck. That should remove the top axis. You may have to click the gear icon towards the top right of the Properties panel to see it.
Hey I am using axes grid but I cannot see anythin called Chart views or Show Top axis grid. Am i missing anything? I have turned on the gear. Can you please let me know, thanks
Sorry, it wasn’t clear to me what you were asking about. Now I understand you have the Axes Grid option checked in the Properties panel. I guess by top you mean the maximum z-axis. I’m afraid it is not possible to disable only the axes along the maximum or minimum of the x, y, or z axes.
