showing vorticity with vtr file : paraview 5.7
hello all,
just to say I think there is a bug when showing vorticity with paraview 5.7 (https://www.paraview.org/paraview-downloads/download.php?submit=Download&version=v5.7&type=binary&os=Linux&downloadFile=ParaView-5.7.0-MPI-Linux-Python3.7-64bit.tar.gz)
You can avoid it with pvbatch, by changing [CELLS] to [POINTS] :slight_smile, like this :
 # create a new 'Compute Derivatives'
  computeDerivatives1 = ComputeDerivatives(Input=vitvtr)
  computeDerivatives1.Scalars = ['POINTS', 'vit_Magnitude']
  computeDerivatives1.Vectors = ['POINTS', 'vit']
  computeDerivatives1.OutputVectorType = 'Vorticity'
# create a new 'Contour'
  contour1 = Contour(Input=transform2)
  #contour1.ContourBy = ['CELLS', 'Vorticity_Magnitude']
  **contour1.ContourBy = ['POINTS', 'Vorticity_Magnitude']**
  contour1.Isosurfaces = [1.5]
  contour1.PointMergeMethod = 'Uniform Binning'
OR you can calculated vorticity like in older release, by defining the gradient (see below).
I hope it can help someone
Code Example
Vort_calculated_by_paraview.py (12.7 KB)
# state file generated using paraview version 5.7.0
# setup views used in the visualization
# trace generated using paraview version 5.7.0
# To ensure correct image size when batch processing, please search
# for and uncomment the line `# renderView*.ViewSize = [*,*]`
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
# get the material library
materialLibrary1 = GetMaterialLibrary()
# Create a new 'Render View'
renderView1 = CreateView('RenderView')
renderView1.ViewSize = [1500, 850]
renderView1.AxesGrid = 'GridAxes3DActor'
renderView1.CenterOfRotation = [5.0, 6.0, 3] # centre du cylindre
renderView1.StereoType = 'Crystal Eyes'
renderView1.CameraPosition = [25, 30, 50] # vers l'aval
renderView1.CameraFocalPoint = [10, 5, -4] # derrière le volume
#renderView1.CameraViewUp = [-0.25, 0.95, -0.23] # vue un peu de dessus
renderView1.CameraViewUp = [-0.3, 0.9, -0.3] # vue un peu de dessus
renderView1.CameraFocalDisk = 1.0
renderView1.CameraParallelScale = 1.2
renderView1.Background = [0.32, 0.34, 0.43]
renderView1.BackEnd = 'OSPRay raycaster'
renderView1.OSPRayMaterialLibrary = materialLibrary1
SetActiveView(None)
# setup view layouts
# create new layout object 'Layout #1'
layout1 = CreateLayout(name='Layout #1')
layout1.AssignView(0, renderView1)
# restore active view
SetActiveView(renderView1)
# setup the data processing pipelines
# create a new 'Text'
text1 = Text()
text1.Text = 'iter=150'
# create a new 'Cylinder'
cylinder1 = Cylinder()
cylinder1.Resolution = 25
cylinder1.Height = 6.0
cylinder1.Radius = 0.5
# create a new 'Box'
box1 = Box()
box1.XLength = 20.0
box1.YLength = 12.0
box1.ZLength = 6.0
box1.Center = [10.0, 6.0, 3.0]
# create a new 'Transform'
transform1 = Transform(Input=cylinder1)
transform1.Transform = 'Transform'
# init the 'Transform' selected for 'Transform'
transform1.Transform.Translate = [5.0, 6.0, 3.0]
transform1.Transform.Rotate = [90.0, 0.0, 0.0]
# create a new 'XML Rectilinear Grid Reader'
vitvtr = XMLRectilinearGridReader(FileName=[Vit.vtr'])
#vitvtr.PointArrayStatus = ['vit', 'vit_norm']
vitvtr.PointArrayStatus = ['vit']
### VORTICITY colored by VELOCITY ###
code_vort = 2
############### CONTOUR by [computeDerivatives = vorticiy] -> ERROR : [POINT] not [CELLS] ##############
if code_vort == 1:
  transform2 = Transform(Input=computeDerivatives1)
  transform2.Transform = 'Transform'
  transform2.Transform.Translate = [8.0, 2.0, 0.0]
############### CONTOUR by [computeDerivatives = gradient] ##############
else:
  computeDerivatives1.OutputVectorType = 'Scalar Gradient'
  # create a new 'Calculator'
  calculator1 = Calculator(Input=transform2)
  calculator1.AttributeType = 'Cell Data'
  calculator1.ResultArrayName = 'vort'
  calculator1.Function = '(VectorGradient_5-VectorGradient_7)*iHat+(VectorGradient_6-VectorGradient_2)*jHat+(VectorGradient_1-VectorGradient_3)*kHat'
  # create a new 'Cell Data to Point Data'
  cellDatatoPointData1 = CellDatatoPointData(Input=calculator1)
  #cellDatatoPointData1.CellDataArraytoprocess = ['vit', 'vit_Magnitude', 'ScalarGradient', 'VectorGradient', 'VectorGradient_Magnitude', 'vort']
  cellDatatoPointData1.CellDataArraytoprocess = ['vit', 'vit_Magnitude', 'vort', 'vort_Magnitude']
  contour1 = Contour(Input=cellDatatoPointData1)
  contour1.ContourBy = ['POINTS', 'vort_Magnitude']
Hi, sorry, your post was not approved as a tips and tricks as it seems very specific.
Could you elaborate on the bug though. What is not working as expected ?
I’m sorry if it wasn’t clear enough : in fact when using paraview with GUI, the generation of vorticity from velocity vector is wrong.
One way I found to correct this was to use the online launcher (pvbatch python_file) : after saving state in python file, I modify the python file either by replacing CELLS by POINTs in contour defining, or by calculating vorticity from grad(velocity).
I hope it’s more clear !
How do you generate vorticity ? What is wrong about it ?
to generate vorticity I simply choose Vorticity in computeDerivatives, but the result isn’t correct, that why I’ve modified the python file after saving the state in this format
bad view without modifying the python script =
good view when modifying the python script =
Could you share this vit.vtr ?
of course I try to tar it in order to make it smaller an d send it
P.S. its structure is as below
VTR file : file is to big
I try to reduce it to some points
here is a
vtr file (1 point kept every 3 points of the previous vtr file)
test.vtr.tar.gz (1.9 MB)
here the python file to obtain the image file below
test.py (12.8 KB)
The contour filter does not support contouring by cells at all, even though python let you do it, you cannot select a cell array using the GUI.
Why did you write this line in the first place ? :
I have’nt chosen to write this line, it was automatically produced when saving the state in python file. And as I have already used older release of paraview in which you must passed CELLs to POSTs in order to compute derivatives before defining vorticity (like in the second part of the [if loop]), I’ve changed this line, and it works.
In fact, I’m not surprised that the state python file doesn’t use the right parameter, since the view is wrong in GUI too : it’s not the case with an older paraview (paraview 5.0.1. OS ubuntu) as you can see on this snapshot
but, for a reason I ignore, the same operation with paraview 5.7.0 give this picture :
I’s perhaps related to some OS configuration ??? python conflict ???
Looks like you are using the setting Auto Convert Properties (Edit -> Settings -> AutoConvertProperties).
It indeeds look like this conversion is not done correctly. If you disable this and use CellDataToPointData instead it should be fine in the GUI too.
@cory.quammen : FYI
I’ve tried what you suggested (unselect Edit -> Settings -> AutoConvertProperties) but it doesn’t work : I can have velocity (contour) colored by vorticity, but not vorticity colored by velocity since the menu Contour By doesn’t let me choose another thing than vit_norm. In fact, the result is the same with or without CellData to PointData before Contour.
never mind, there is always the solution of redefining the vorticity!
have a good day
… and thank you again for your help
I’ve tried these two sequences :
1)
  • Compute Derivative
  • CellData to PointData
  • Contour
or 2)
  • Contour
That should be fixed in https://gitlab.kitware.com/paraview/paraview/merge_requests/3855
thank you for your help, but my installed paraview is a compiled one : I suppose you should have source files to make the changes in [Qt/Components/pqArraySelectorPropertyWidget.cxx] ?
previously, I was used to making the install from the source files, but today, excepted this error, compiled paraview 5.7 work fine; for me the most important is to have pvbatch work correctly : I use the GUI only to have a model view, and then save the state in python, in order to modify it easily with unix tools.
however, I keep this information in mind, it can be useful for other releases, or for detecting other dysfunction
have a good day
You can just download the nightly or the upcoming 5.8RC2 release to get the fix.
