Hi everyone.
I’d like to add pyarrow to pvpython so that it can read/write .parquet files.
I managed on my local machine, but had to go through the quite tedious method of building paraview from scratch.
I’d like to know, since I want to share my code using .parquet with others, if there is a more straightforward way?
I did find that using virtual environment could help, as explained here: https://www.kitware.com/using-pvpython-and-virtualenv/
The issue is that I seem to have conflict when I do so using the paraview version from the website. When I build my environment and then use the commands:
vEnv='/home/environments/paraview_env/bin/activate_this.py'
exec(open(vEnv).read(), {'__file__': vEnv})
Then it seems like simple libraries as numpy wont work anymore, with error as such as:
>>> import pandas as pd
  File "<stdin>", line 1, in <module>
  File "/home/boris/environments/paraview_env/lib/python3.10/site-packages/pandas/__init__.py", line 22, in <module>
    from pandas.compat import is_numpy_dev as _is_numpy_dev  # pyright: ignore # noqa:F401
  File "/home/boris/environments/paraview_env/lib/python3.10/site-packages/pandas/compat/__init__.py", line 18, in <module>
    from pandas.compat.numpy import (
  File "/home/boris/environments/paraview_env/lib/python3.10/site-packages/pandas/compat/numpy/__init__.py", line 4, in <module>
    from pandas.util.version import Version
  File "/home/boris/environments/paraview_env/lib/python3.10/site-packages/pandas/util/__init__.py", line 2, in <module>
    from pandas.util._decorators import (  # noqa:F401
  File "/home/boris/environments/paraview_env/lib/python3.10/site-packages/pandas/util/_decorators.py", line 14, in <module>
    from pandas._libs.properties import cache_readonly
  File "/home/boris/environments/paraview_env/lib/python3.10/site-packages/pandas/_libs/__init__.py", line 13, in <module>
    from pandas._libs.interval import Interval
ModuleNotFoundError: No module named 'pandas._libs.interval'
Meanwhile, if I import pandas without the venv, it works… Any clue, or other way of importing my modules?
Thank you!
