I have two XMLUnstructuredGrid data sets, each with a set of points (a regular grid actually…) carrying a scalar field.
The two data sets are nearly homothetical one with respect to another: they include the same number of points/cells (within a 10% variation, and have the same memory footprint) but with different inter-points spacings. For instance 1 for one data set, and 3 for the other
Yet, the computational costs using Delaunay3D filter (to turn each discrete data set into a continuous one, before extracting iso-surfaces) in ParaView 5.4.1 are completely differents.
There is a 10 ratio in the memory footprint of created Delaunay3D objects in the pipeline (5.1 MB for the one stemming from the “small” grid, 52 MB for the “big” one), together with a 26* increase in the number of cells (but the same number of points)
And there is a ~ 200 ratio in execution time cost of my workflow…
(Good news is the final iso-surfaces are pretty much homothetic, as expected)
I’m kind of a beginner and run Delaunay3D with default parameters. Maybe there is some dimensional attribute, but I could not find it… (I understand from the doc Tolerance attribute is not a possible one because it is a ratio ?)
What is the reason for this size (or unit)-dependent behavior ?
Thanks
