Slice/clip with surface not working
I would like to do this with a surface created from the filter connectivity (use the freesurface to cut my volume) extract interface between water and air - #3 by Kenneth_Moreland
Is this possible? the type of the connectivity output is unstructured grid. not sure if I should transform this data to a specific format. I am not getting any error but I also not getting anything as ouput
This should be possible, please share your data.
hello mathieu,
exactly the same data you just replied in this thread issue with following height of free surface in VOF simulation, paraview crashes when using plot over time
hello mathieu,
any inputs in this regards? normally the files are still up. I need to calculate the gas holdup of my reactor (so the total volume down the free surface of the liquid/gas interphase) and it is the only way i find logic to do (if i do a threashold of 0.5 it will ‘remove’ cells inside the fluid part that are filled with gas (and i dont want this).
regards
I’m afraid files are not up anymore.
