# trace generated using paraview version 5.7.0
# To ensure correct image size when batch processing, please search
# for and uncomment the line `# renderView*.ViewSize = [*,*]`
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
# create a new 'CGNS Series Reader'
cH4_1500ls_50P_60m3scgns = CGNSSeriesReader(FileNames=['C:\\ParaView-5.7.0\\DATA\\Results\\CH4_1500ls_50P_60m3s.cgns'])
cH4_1500ls_50P_60m3scgns.Blocks = ['/Hierarchy/Base/Zone/Grid']
cH4_1500ls_50P_60m3scgns.PointArrayStatus = []
# get active view
# uncomment following to set a specific view size
# renderView1.ViewSize = [1627, 821]
# Properties modified on renderView1
renderView1.EnableRayTracing = 1
# get the material library
materialLibrary1 = GetMaterialLibrary()
renderView1.Background = [0.8784313725490196, 0.8784313725490196, 0.8784313725490196]
# Properties modified on cH4_1500ls_50P_60m3scgns
cH4_1500ls_50P_60m3scgns.Blocks = ['/Hierarchy/Base/Zone/Grid', '/Hierarchy/Base/Zone/c1', '/Hierarchy/Base/Zone/c10', '/Hierarchy/Base/Zone/c2', '/Hierarchy/Base/Zone/c3', '/Hierarchy/Base/Zone/c4', '/Hierarchy/Base/Zone/c5', '/Hierarchy/Base/Zone/c6', '/Hierarchy/Base/Zone/c7', '/Hierarchy/Base/Zone/c8', '/Hierarchy/Base/Zone/c9', '/Hierarchy/Base/Zone/f_mg1', '/Hierarchy/Base/Zone/f_mg10', '/Hierarchy/Base/Zone/f_mg11', '/Hierarchy/Base/Zone/f_mg12', '/Hierarchy/Base/Zone/f_mg13', '/Hierarchy/Base/Zone/f_mg14', '/Hierarchy/Base/Zone/f_mg15', '/Hierarchy/Base/Zone/f_mg16', '/Hierarchy/Base/Zone/f_mg17', '/Hierarchy/Base/Zone/f_mg18', '/Hierarchy/Base/Zone/f_mg19', '/Hierarchy/Base/Zone/f_mg2', '/Hierarchy/Base/Zone/f_mg20', '/Hierarchy/Base/Zone/f_mg3', '/Hierarchy/Base/Zone/f_mg4', '/Hierarchy/Base/Zone/f_mg5', '/Hierarchy/Base/Zone/f_mg6', '/Hierarchy/Base/Zone/f_mg7', '/Hierarchy/Base/Zone/f_mg8', '/Hierarchy/Base/Zone/f_mg9', '/Hierarchy/Base/Zone/f_st1', '/Hierarchy/Base/Zone/f_st2', '/Hierarchy/Base/Zone/f_tg1', '/Hierarchy/Base/Zone/f_tg10', '/Hierarchy/Base/Zone/f_tg11', '/Hierarchy/Base/Zone/f_tg12', '/Hierarchy/Base/Zone/f_tg13', '/Hierarchy/Base/Zone/f_tg14', '/Hierarchy/Base/Zone/f_tg15', '/Hierarchy/Base/Zone/f_tg16', '/Hierarchy/Base/Zone/f_tg17', '/Hierarchy/Base/Zone/f_tg18', '/Hierarchy/Base/Zone/f_tg19', '/Hierarchy/Base/Zone/f_tg2', '/Hierarchy/Base/Zone/f_tg20', '/Hierarchy/Base/Zone/f_tg3', '/Hierarchy/Base/Zone/f_tg4', '/Hierarchy/Base/Zone/f_tg6', '/Hierarchy/Base/Zone/f_tg7', '/Hierarchy/Base/Zone/f_tg8', '/Hierarchy/Base/Zone/f_tg9', '/Hierarchy/Base/Zone/fg_5', '/Hierarchy/Base/Zone/inlet1', '/Hierarchy/Base/Zone/inlet2', '/Hierarchy/Base/Zone/interior-part-2-042', '/Hierarchy/Base/Zone/interior-part-2-trans2-041', '/Hierarchy/Base/Zone/outlet1', '/Hierarchy/Base/Zone/outlet2', '/Hierarchy/Base/Zone/seam_l-gg', '/Hierarchy/Base/Zone/seam_l-goaf', '/Hierarchy/Base/Zone/seam_l-part-1', '/Hierarchy/Base/Zone/seam_l-part-2', '/Hierarchy/Base/Zone/seam_l-part-7', '/Hierarchy/Base/Zone/seam_l-roadways', '/Hierarchy/Base/Zone/seam_l-solid_canopy', '/Hierarchy/Base/Zone/seam_l-tg_canopy', '/Hierarchy/Base/Zone/seam_l-tg_fluid_r1', '/Hierarchy/Base/Zone/seam_l-tg_roadway', '/Hierarchy/Base/Zone/seam_l-trans1', '/Hierarchy/Base/Zone/seam_l-trans2', '/Hierarchy/Base/Zone/shaft_inlet', '/Hierarchy/Base/Zone/wall-floor', '/Hierarchy/Base/Zone/wall-front_leg', '/Hierarchy/Base/Zone/wall-front_leg-solid_base', '/Hierarchy/Base/Zone/wall-front_leg-solid_canopy', '/Hierarchy/Base/Zone/wall-gg', '/Hierarchy/Base/Zone/wall-gg-solid_base', '/Hierarchy/Base/Zone/wall-goaf', '/Hierarchy/Base/Zone/wall-link1-solid_canopy', '/Hierarchy/Base/Zone/wall-link2', '/Hierarchy/Base/Zone/wall-link2-solid_base', '/Hierarchy/Base/Zone/wall-mg1', '/Hierarchy/Base/Zone/wall-mg10', '/Hierarchy/Base/Zone/wall-mg11', '/Hierarchy/Base/Zone/wall-mg12', '/Hierarchy/Base/Zone/wall-mg13', '/Hierarchy/Base/Zone/wall-mg16', '/Hierarchy/Base/Zone/wall-mg17', '/Hierarchy/Base/Zone/wall-mg2', '/Hierarchy/Base/Zone/wall-mg20', '/Hierarchy/Base/Zone/wall-mg3', '/Hierarchy/Base/Zone/wall-mg4', '/Hierarchy/Base/Zone/wall-mg5', '/Hierarchy/Base/Zone/wall-mg6', '/Hierarchy/Base/Zone/wall-mg7', '/Hierarchy/Base/Zone/wall-mg8', '/Hierarchy/Base/Zone/wall-mg9', '/Hierarchy/Base/Zone/wall-mg_14', '/Hierarchy/Base/Zone/wall-mg_15', '/Hierarchy/Base/Zone/wall-mg_18', '/Hierarchy/Base/Zone/wall-mg_19', '/Hierarchy/Base/Zone/wall-motor_ext-solid_tg_motor', '/Hierarchy/Base/Zone/wall-part-1', '/Hierarchy/Base/Zone/wall-part-1-solid_base', '/Hierarchy/Base/Zone/wall-part-1-solid_canopy', '/Hierarchy/Base/Zone/wall-part-116', '/Hierarchy/Base/Zone/wall-part-120', '/Hierarchy/Base/Zone/wall-part-121', '/Hierarchy/Base/Zone/wall-part-122', '/Hierarchy/Base/Zone/wall-part-123', '/Hierarchy/Base/Zone/wall-part-124', '/Hierarchy/Base/Zone/wall-part-125', '/Hierarchy/Base/Zone/wall-part-126', '/Hierarchy/Base/Zone/wall-part-127', '/Hierarchy/Base/Zone/wall-part-128', '/Hierarchy/Base/Zone/wall-part-129', '/Hierarchy/Base/Zone/wall-part-2', '/Hierarchy/Base/Zone/wall-part-2-solid_base', '/Hierarchy/Base/Zone/wall-part-2-solid_base-123', '/Hierarchy/Base/Zone/wall-part-2-solid_canopy', '/Hierarchy/Base/Zone/wall-part-2-solid_tg_motor', '/Hierarchy/Base/Zone/wall-part-2-solid_tg_motor-060', '/Hierarchy/Base/Zone/wall-part-3', '/Hierarchy/Base/Zone/wall-part-3-solid_bsl', '/Hierarchy/Base/Zone/wall-part-5', '/Hierarchy/Base/Zone/wall-part-6', '/Hierarchy/Base/Zone/wall-part-7', '/Hierarchy/Base/Zone/wall-part-7-solid_base', '/Hierarchy/Base/Zone/wall-part-7-solid_bsl', '/Hierarchy/Base/Zone/wall-part-7-solid_canopy', '/Hierarchy/Base/Zone/wall-roadways', '/Hierarchy/Base/Zone/wall-seam', '/Hierarchy/Base/Zone/wall-solid_base', '/Hierarchy/Base/Zone/wall-solid_base-tg_base', '/Hierarchy/Base/Zone/wall-solid_base-trans1', '/Hierarchy/Base/Zone/wall-solid_base-trans2', '/Hierarchy/Base/Zone/wall-solid_bsl', '/Hierarchy/Base/Zone/wall-solid_bsl-trans1', '/Hierarchy/Base/Zone/wall-solid_canopy', '/Hierarchy/Base/Zone/wall-solid_canopy-tg_canopy', '/Hierarchy/Base/Zone/wall-solid_canopy-trans1', '/Hierarchy/Base/Zone/wall-solid_canopy-trans2', '/Hierarchy/Base/Zone/wall-st1', '/Hierarchy/Base/Zone/wall-st2', '/Hierarchy/Base/Zone/wall-tg1', '/Hierarchy/Base/Zone/wall-tg10', '/Hierarchy/Base/Zone/wall-tg11', '/Hierarchy/Base/Zone/wall-tg12', '/Hierarchy/Base/Zone/wall-tg13', '/Hierarchy/Base/Zone/wall-tg14', '/Hierarchy/Base/Zone/wall-tg15', '/Hierarchy/Base/Zone/wall-tg16', '/Hierarchy/Base/Zone/wall-tg17', '/Hierarchy/Base/Zone/wall-tg18', '/Hierarchy/Base/Zone/wall-tg19', '/Hierarchy/Base/Zone/wall-tg2', '/Hierarchy/Base/Zone/wall-tg20', '/Hierarchy/Base/Zone/wall-tg3', '/Hierarchy/Base/Zone/wall-tg4', '/Hierarchy/Base/Zone/wall-tg5', '/Hierarchy/Base/Zone/wall-tg6', '/Hierarchy/Base/Zone/wall-tg7', '/Hierarchy/Base/Zone/wall-tg8', '/Hierarchy/Base/Zone/wall-tg9', '/Hierarchy/Base/Zone/wall-tg_base', '/Hierarchy/Base/Zone/wall-tg_fluid_r1', '/Hierarchy/Base/Zone/wall-tg_roadway', '/Hierarchy/Base/Zone/wall-trans1', '/Hierarchy/Base/Zone/wall-trans2', '/Hierarchy/Base/Zone/wall_c1', '/Hierarchy/Base/Zone/wall_tg1', '/Hierarchy/Base/Zone/wall_tg10', '/Hierarchy/Base/Zone/wall_tg11', '/Hierarchy/Base/Zone/wall_tg2', '/Hierarchy/Base/Zone/wall_tg3', '/Hierarchy/Base/Zone/wall_tg4', '/Hierarchy/Base/Zone/wall_tg5', '/Hierarchy/Base/Zone/wall_tg6', '/Hierarchy/Base/Zone/wall_tg7', '/Hierarchy/Base/Zone/wall_tg8', '/Hierarchy/Base/Zone/wall_tg9', '/Hierarchy/Base/Zone/xf']
cH4_1500ls_50P_60m3scgns.PointArrayStatus = ['Coordinate', 'Mole_fraction_of_ch4', 'Mole_fraction_of_co2', 'Mole_fraction_of_n2', 'Mole_fraction_of_o2', 'Pressure', 'VelocityMagnitude']
# show data in view
cH4_1500ls_50P_60m3scgnsDisplay = Show(cH4_1500ls_50P_60m3scgns, renderView1)
# trace defaults for the display properties.
cH4_1500ls_50P_60m3scgnsDisplay.Representation = 'Surface'
cH4_1500ls_50P_60m3scgnsDisplay.ColorArrayName = [None, '']
cH4_1500ls_50P_60m3scgnsDisplay.OSPRayScaleArray = 'Coordinate'
cH4_1500ls_50P_60m3scgnsDisplay.OSPRayScaleFunction = 'PiecewiseFunction'
cH4_1500ls_50P_60m3scgnsDisplay.SelectOrientationVectors = 'Coordinate'
cH4_1500ls_50P_60m3scgnsDisplay.ScaleFactor = 128.56999969482422
cH4_1500ls_50P_60m3scgnsDisplay.SelectScaleArray = 'Coordinate'
cH4_1500ls_50P_60m3scgnsDisplay.GlyphType = 'Arrow'
cH4_1500ls_50P_60m3scgnsDisplay.GlyphTableIndexArray = 'Coordinate'
cH4_1500ls_50P_60m3scgnsDisplay.GaussianRadius = 6.428499984741211
cH4_1500ls_50P_60m3scgnsDisplay.SetScaleArray = ['POINTS', 'Coordinate']
cH4_1500ls_50P_60m3scgnsDisplay.ScaleTransferFunction = 'PiecewiseFunction'
cH4_1500ls_50P_60m3scgnsDisplay.OpacityArray = ['POINTS', 'Coordinate']
cH4_1500ls_50P_60m3scgnsDisplay.OpacityTransferFunction = 'PiecewiseFunction'
cH4_1500ls_50P_60m3scgnsDisplay.DataAxesGrid = 'GridAxesRepresentation'
cH4_1500ls_50P_60m3scgnsDisplay.PolarAxes = 'PolarAxesRepresentation'
cH4_1500ls_50P_60m3scgnsDisplay.ScalarOpacityUnitDistance = 17.15648836852911
cH4_1500ls_50P_60m3scgnsDisplay.ExtractedBlockIndex = 3
# init the 'PiecewiseFunction' selected for 'ScaleTransferFunction'
cH4_1500ls_50P_60m3scgnsDisplay.ScaleTransferFunction.Points = [-79.9852066040039, 0.0, 0.5, 0.0, 391.785400390625, 1.0, 0.5, 0.0]
# init the 'PiecewiseFunction' selected for 'OpacityTransferFunction'
cH4_1500ls_50P_60m3scgnsDisplay.OpacityTransferFunction.Points = [-79.9852066040039, 0.0, 0.5, 0.0, 391.785400390625, 1.0, 0.5, 0.0]
# reset view to fit data
renderView1.ResetCamera()
# update the view to ensure updated data information
renderView1.Update()
# set scalar coloring
ColorBy(cH4_1500ls_50P_60m3scgnsDisplay, ('FIELD', 'vtkBlockColors'))
# show color bar/color legend
cH4_1500ls_50P_60m3scgnsDisplay.SetScalarBarVisibility(renderView1, True)
# get color transfer function/color map for 'vtkBlockColors'
vtkBlockColorsLUT = GetColorTransferFunction('vtkBlockColors')
# get opacity transfer function/opacity map for 'vtkBlockColors'
vtkBlockColorsPWF = GetOpacityTransferFunction('vtkBlockColors')
# Hide orientation axes
renderView1.OrientationAxesVisibility = 0
# turn off scalar coloring
ColorBy(cH4_1500ls_50P_60m3scgnsDisplay, None)
# Hide the scalar bar for this color map if no visible data is colored by it.
HideScalarBarIfNotNeeded(vtkBlockColorsLUT, renderView1)
# change representation type
cH4_1500ls_50P_60m3scgnsDisplay.SetRepresentationType('Feature Edges')
# create a new 'Calculator'
calculator1 = Calculator(Input=cH4_1500ls_50P_60m3scgns)
calculator1.Function = ''
# Properties modified on calculator1
calculator1.Function = 'Mole_fraction_of_ch4*100'
# show data in view
calculator1Display = Show(calculator1, renderView1)
# get color transfer function/color map for 'Result'
resultLUT = GetColorTransferFunction('Result')
# get opacity transfer function/opacity map for 'Result'
resultPWF = GetOpacityTransferFunction('Result')
calculator1Display.Representation = 'Surface'
calculator1Display.ColorArrayName = ['POINTS', 'Result']
calculator1Display.LookupTable = resultLUT
calculator1Display.OSPRayScaleArray = 'Result'
calculator1Display.OSPRayScaleFunction = 'PiecewiseFunction'
calculator1Display.SelectOrientationVectors = 'Coordinate'
calculator1Display.ScaleFactor = 128.56999969482422
calculator1Display.SelectScaleArray = 'Result'
calculator1Display.GlyphType = 'Arrow'
calculator1Display.GlyphTableIndexArray = 'Result'
calculator1Display.GaussianRadius = 6.428499984741211
calculator1Display.SetScaleArray = ['POINTS', 'Result']
calculator1Display.ScaleTransferFunction = 'PiecewiseFunction'
calculator1Display.OpacityArray = ['POINTS', 'Result']
calculator1Display.OpacityTransferFunction = 'PiecewiseFunction'
calculator1Display.DataAxesGrid = 'GridAxesRepresentation'
calculator1Display.PolarAxes = 'PolarAxesRepresentation'
calculator1Display.ScalarOpacityFunction = resultPWF
calculator1Display.ScalarOpacityUnitDistance = 17.15648836852911
calculator1Display.ExtractedBlockIndex = 3
calculator1Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.93855953216553, 1.0, 0.5, 0.0]
calculator1Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.93855953216553, 1.0, 0.5, 0.0]
# hide data in view
Hide(cH4_1500ls_50P_60m3scgns, renderView1)
calculator1Display.SetScalarBarVisibility(renderView1, True)
# hide data in view
Hide(calculator1, renderView1)
# set active source
SetActiveSource(cH4_1500ls_50P_60m3scgns)
# set active source
SetActiveSource(calculator1)
# create a new 'Contour'
contour1 = Contour(Input=calculator1)
contour1.ContourBy = ['POINTS', 'Result']
contour1.Isosurfaces = [24.969279766082764]
contour1.PointMergeMethod = 'Uniform Binning'
# Properties modified on contour1
contour1.Isosurfaces = [0.0, 5.0, 10.0, 15.0, 20.0, 25.0, 30.0, 35.0, 40.0, 45.0, 50.0]
# show data in view
contour1Display = Show(contour1, renderView1)
contour1Display.Representation = 'Surface'
contour1Display.ColorArrayName = ['POINTS', 'Result']
contour1Display.LookupTable = resultLUT
contour1Display.OSPRayScaleArray = 'Result'
contour1Display.OSPRayScaleFunction = 'PiecewiseFunction'
contour1Display.SelectOrientationVectors = 'Coordinate'
contour1Display.ScaleFactor = 99.33892673516476
contour1Display.SelectScaleArray = 'Result'
contour1Display.GlyphType = 'Arrow'
contour1Display.GlyphTableIndexArray = 'Result'
contour1Display.GaussianRadius = 4.966946336758237
contour1Display.SetScaleArray = ['POINTS', 'Result']
contour1Display.ScaleTransferFunction = 'PiecewiseFunction'
contour1Display.OpacityArray = ['POINTS', 'Result']
contour1Display.OpacityTransferFunction = 'PiecewiseFunction'
contour1Display.DataAxesGrid = 'GridAxesRepresentation'
contour1Display.PolarAxes = 'PolarAxesRepresentation'
contour1Display.ScaleTransferFunction.Points = [5.0, 0.0, 0.5, 0.0, 45.0, 1.0, 0.5, 0.0]
contour1Display.OpacityTransferFunction.Points = [5.0, 0.0, 0.5, 0.0, 45.0, 1.0, 0.5, 0.0]
# hide data in view
contour1Display.SetScalarBarVisibility(renderView1, True)
# set active source
# show data in view
# set active source
SetActiveSource(contour1)
# Apply a preset using its name. Note this may not work as expected when presets have duplicate names.
resultLUT.ApplyPreset('jet', True)
# get color legend/bar for resultLUT in view renderView1
resultLUTColorBar = GetScalarBar(resultLUT, renderView1)
# Properties modified on resultLUTColorBar
resultLUTColorBar.WindowLocation = 'AnyLocation'
resultLUTColorBar.Position = [0.95, 0.45]
resultLUTColorBar.TitleColor = [0.0, 0.0, 0.0]
resultLUTColorBar.LabelColor = [0.0, 0.0, 0.0]
resultLUTColorBar.AddRangeLabels = 0
# Rescale transfer function
resultLUT.RescaleTransferFunction(0.0, 50.0)
resultPWF.RescaleTransferFunction(0.0, 50.0)
# set active source
# create a new 'Clip'
clip1 = Clip(Input=calculator1)
clip1.ClipType = 'Plane'
clip1.Scalars = ['POINTS', 'Result']
clip1.Value = 24.969279766082764
# init the 'Plane' selected for 'ClipType'
clip1.ClipType.Origin = [155.90009689331055, 126.3176097869873, 667.1500015258789]
# toggle 3D widget visibility (only when running from the GUI)
Hide3DWidgets(proxy=clip1.ClipType)
# Properties modified on clip1.ClipType
clip1.ClipType.Origin = [2.5, 0.0, 0.0]
# show data in view
clip1Display = Show(clip1, renderView1)
clip1Display.Representation = 'Surface'
clip1Display.ColorArrayName = ['POINTS', 'Result']
clip1Display.LookupTable = resultLUT
clip1Display.OSPRayScaleArray = 'Result'
clip1Display.OSPRayScaleFunction = 'PiecewiseFunction'
clip1Display.SelectOrientationVectors = 'Coordinate'
clip1Display.ScaleFactor = 116.56999969482422
clip1Display.SelectScaleArray = 'Result'
clip1Display.GlyphType = 'Arrow'
clip1Display.GlyphTableIndexArray = 'Result'
clip1Display.GaussianRadius = 5.828499984741211
clip1Display.SetScaleArray = ['POINTS', 'Result']
clip1Display.ScaleTransferFunction = 'PiecewiseFunction'
clip1Display.OpacityArray = ['POINTS', 'Result']
clip1Display.OpacityTransferFunction = 'PiecewiseFunction'
clip1Display.DataAxesGrid = 'GridAxesRepresentation'
clip1Display.PolarAxes = 'PolarAxesRepresentation'
clip1Display.ScalarOpacityFunction = resultPWF
clip1Display.ScalarOpacityUnitDistance = 31.81075688864021
clip1Display.ExtractedBlockIndex = 3
# init the 'PiecewiseFunction' selected for 'OSPRayScaleFunction'
clip1Display.OSPRayScaleFunction.Points = [0.0, 0.0, 0.5, 0.0, 50.0, 1.0, 0.5, 0.0]
clip1Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.82861203513568, 1.0, 0.5, 0.0]
clip1Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.82861203513568, 1.0, 0.5, 0.0]
# hide data in view
clip1Display.SetScalarBarVisibility(renderView1, True)
# set active source
# create a new 'Slice'
slice1 = Slice(Input=calculator1)
slice1.SliceType = 'Plane'
slice1.SliceOffsetValues = [0.0]
# init the 'Plane' selected for 'SliceType'
slice1.SliceType.Origin = [155.90009689331055, 126.3176097869873, 667.1500015258789]
# set active source
# destroy slice1
Delete(slice1)
del slice1
# set active source
SetActiveSource(clip1)
# set active source
# hide data in view
Hide(clip1, renderView1)
# show data in view
# destroy clip1
Delete(clip1)
del clip1
Hide3DWidgets(proxy=slice1.SliceType)
# hide data in view
Hide(contour1, renderView1)
# hide data in view
# set active source
# show data in view
# set active source
SetActiveSource(slice1)
# Properties modified on slice1.SliceType
slice1.SliceType.Origin = [2.5, 0.0, 0.0]
# show data in view
slice1Display = Show(slice1, renderView1)
slice1Display.Representation = 'Surface'
slice1Display.ColorArrayName = ['POINTS', 'Result']
slice1Display.LookupTable = resultLUT
slice1Display.OSPRayScaleArray = 'Result'
slice1Display.OSPRayScaleFunction = 'PiecewiseFunction'
slice1Display.SelectOrientationVectors = 'Coordinate'
slice1Display.ScaleFactor = 116.56999969482422
slice1Display.SelectScaleArray = 'Result'
slice1Display.GlyphType = 'Arrow'
slice1Display.GlyphTableIndexArray = 'Result'
slice1Display.GaussianRadius = 5.828499984741211
slice1Display.SetScaleArray = ['POINTS', 'Result']
slice1Display.ScaleTransferFunction = 'PiecewiseFunction'
slice1Display.OpacityArray = ['POINTS', 'Result']
slice1Display.OpacityTransferFunction = 'PiecewiseFunction'
slice1Display.DataAxesGrid = 'GridAxesRepresentation'
slice1Display.PolarAxes = 'PolarAxesRepresentation'
slice1Display.OSPRayScaleFunction.Points = [0.0, 0.0, 0.5, 0.0, 50.0, 1.0, 0.5, 0.0]
slice1Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.82861203513568, 1.0, 0.5, 0.0]
slice1Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.82861203513568, 1.0, 0.5, 0.0]
# hide data in view
slice1Display.SetScalarBarVisibility(renderView1, True)
# set active source
slice2 = Slice(Input=calculator1)
slice2.SliceType = 'Plane'
slice2.SliceOffsetValues = [0.0]
slice2.SliceType.Origin = [155.90009689331055, 126.3176097869873, 667.1500015258789]
Hide3DWidgets(proxy=slice2.SliceType)
# Properties modified on slice2.SliceType
slice2.SliceType.Origin = [155.90009689331055, 0.0, 0.0]
# show data in view
slice2Display = Show(slice2, renderView1)
slice2Display.Representation = 'Surface'
slice2Display.ColorArrayName = ['POINTS', 'Result']
slice2Display.LookupTable = resultLUT
slice2Display.OSPRayScaleArray = 'Result'
slice2Display.OSPRayScaleFunction = 'PiecewiseFunction'
slice2Display.SelectOrientationVectors = 'Coordinate'
slice2Display.ScaleFactor = 109.07000274658203
slice2Display.SelectScaleArray = 'Result'
slice2Display.GlyphType = 'Arrow'
slice2Display.GlyphTableIndexArray = 'Result'
slice2Display.GaussianRadius = 5.453500137329102
slice2Display.SetScaleArray = ['POINTS', 'Result']
slice2Display.ScaleTransferFunction = 'PiecewiseFunction'
slice2Display.OpacityArray = ['POINTS', 'Result']
slice2Display.OpacityTransferFunction = 'PiecewiseFunction'
slice2Display.DataAxesGrid = 'GridAxesRepresentation'
slice2Display.PolarAxes = 'PolarAxesRepresentation'
slice2Display.OSPRayScaleFunction.Points = [0.0, 0.0, 0.5, 0.0, 50.0, 1.0, 0.5, 0.0]
slice2Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.93852782251906, 1.0, 0.5, 0.0]
slice2Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.93852782251906, 1.0, 0.5, 0.0]
# hide data in view
slice2Display.SetScalarBarVisibility(renderView1, True)
# set active source
slice3 = Slice(Input=calculator1)
slice3.SliceType = 'Plane'
slice3.SliceOffsetValues = [0.0]
slice3.SliceType.Origin = [155.90009689331055, 126.3176097869873, 667.1500015258789]
Hide3DWidgets(proxy=slice3.SliceType)
# Properties modified on slice3.SliceType
slice3.SliceType.Origin = [0.0, 0.0, 110.0]
slice3.SliceType.Normal = [0.0, 0.0, 1.0]
# show data in view
slice3Display = Show(slice3, renderView1)
slice3Display.Representation = 'Surface'
slice3Display.ColorArrayName = ['POINTS', 'Result']
slice3Display.LookupTable = resultLUT
slice3Display.OSPRayScaleArray = 'Result'
slice3Display.OSPRayScaleFunction = 'PiecewiseFunction'
slice3Display.SelectOrientationVectors = 'Coordinate'
slice3Display.ScaleFactor = 47.1770378112793
slice3Display.SelectScaleArray = 'Result'
slice3Display.GlyphType = 'Arrow'
slice3Display.GlyphTableIndexArray = 'Result'
slice3Display.GaussianRadius = 2.358851890563965
slice3Display.SetScaleArray = ['POINTS', 'Result']
slice3Display.ScaleTransferFunction = 'PiecewiseFunction'
slice3Display.OpacityArray = ['POINTS', 'Result']
slice3Display.OpacityTransferFunction = 'PiecewiseFunction'
slice3Display.DataAxesGrid = 'GridAxesRepresentation'
slice3Display.PolarAxes = 'PolarAxesRepresentation'
slice3Display.OSPRayScaleFunction.Points = [0.0, 0.0, 0.5, 0.0, 50.0, 1.0, 0.5, 0.0]
slice3Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 27.284336018516072, 1.0, 0.5, 0.0]
slice3Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 27.284336018516072, 1.0, 0.5, 0.0]
# hide data in view
slice3Display.SetScalarBarVisibility(renderView1, True)
# set active source
slice4 = Slice(Input=calculator1)
slice4.SliceType = 'Plane'
slice4.SliceOffsetValues = [0.0]
slice4.SliceType.Origin = [155.90009689331055, 126.3176097869873, 667.1500015258789]
Hide3DWidgets(proxy=slice4.SliceType)
# Properties modified on slice4.SliceType
slice4.SliceType.Origin = [305.0, 0.0, 0.0]
# show data in view
slice4Display = Show(slice4, renderView1)
slice4Display.Representation = 'Surface'
slice4Display.ColorArrayName = ['POINTS', 'Result']
slice4Display.LookupTable = resultLUT
slice4Display.OSPRayScaleArray = 'Result'
slice4Display.OSPRayScaleFunction = 'PiecewiseFunction'
slice4Display.SelectOrientationVectors = 'Coordinate'
slice4Display.ScaleFactor = 108.98000595092309
slice4Display.SelectScaleArray = 'Result'
slice4Display.GlyphType = 'Arrow'
slice4Display.GlyphTableIndexArray = 'Result'
slice4Display.GaussianRadius = 5.449000297546154
slice4Display.SetScaleArray = ['POINTS', 'Result']
slice4Display.ScaleTransferFunction = 'PiecewiseFunction'
slice4Display.OpacityArray = ['POINTS', 'Result']
slice4Display.OpacityTransferFunction = 'PiecewiseFunction'
slice4Display.DataAxesGrid = 'GridAxesRepresentation'
slice4Display.PolarAxes = 'PolarAxesRepresentation'
slice4Display.OSPRayScaleFunction.Points = [0.0, 0.0, 0.5, 0.0, 50.0, 1.0, 0.5, 0.0]
slice4Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.92022871952031, 1.0, 0.5, 0.0]
slice4Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 49.92022871952031, 1.0, 0.5, 0.0]
# hide data in view
slice4Display.SetScalarBarVisibility(renderView1, True)
# current camera placement for renderView1
renderView1.CameraPosition = [1014.5498797184027, 240.9706950424624, 63.39087477888728]
renderView1.CameraFocalPoint = [105.3818178814947, 17.656140412285186, 509.96313778579145]
renderView1.CameraViewUp = [-0.16924722152923635, 0.9751351330961291, 0.1430623996940787]
renderView1.CameraParallelScale = 696.3146820584943
# save screenshot
SaveScreenshot('C:/ParaView-5.7.0/DATA/Results/p1.png', renderView1, ImageResolution=[1910, 821])
renderView1.CameraPosition = [-898.7308061339736, 245.64403147760908, -47.411474539529365]
renderView1.CameraFocalPoint = [-793.5910252289927, 222.20739636431875, 16.150065266578153]
renderView1.CameraViewUp = [0.17761080957751899, 0.9807386521595552, 0.08127789663541601]
renderView1.CameraViewAngle = 25.96335078534031
# save screenshot
SaveScreenshot('C:/ParaView-5.7.0/DATA/Results/p2.png', renderView1, ImageResolution=[1910, 821])
#### saving camera placements for all active views
#### uncomment the following to render all views
# RenderAllViews()
# alternatively, if you want to write images, you can use SaveScreenshot(...).
