This is a truly silly question but, very my bad, i was unable to find a solution.
I have a simulation with three time step saved: 0.08, 0.083 and 0.086. I want to save a simple animation which shows the three results separately with a time delay among them of, let’s say, 5 seconds.
If i simply apply “Save Animation” a video is effectively saved, it lasts simply 3 seconds and it displays the three velocity fields with a time interval of 1 seconds: There is a way to increase the time delay between one frame and the other?
As far as i know i cannot set a FPS lower than 1. Here the screenshot of my saving options:
I repeat myself. Is it a very stupid question but i am totally a newbie in this type of things !
I did as you suggested (hopefully right). But now a new problem arises. I want to plot this chart: in black i have my time variant velocity values along a line; in red the experimental data (constant). Time annotation is fundamental to clarify each time step is considered.
The annotated time changes among one frame and the other (i.e i want it constant among frames, indicating properly the referred time i.e 0.08, 0.086 and 0.089 in my case)
The graphs changes at not the corresponding physical time; i.e the annoted time is wrongly early with respect the real one.
Thank you so much Mathieu, you are saving my master thesis !
Sorry for my late reply Mathieu! It has been a very mess lately!
Shortly i send you my data. You find a “U_exp.csv” file, in which experimental data are saved. I have to plot and compare the numerical results using “PlotOverLine1” where curves (along Ux, Uy, Uz) are shown, as displayed before. The coordinates of the line are:
Point 1: -0.047781; 0.3357; 4.842877388000488e-08
Point 2: 0.095499; 0.3357; 4.842877388000488e-08
