Hi there,
I’m importing vtk data with velocity field and relative contours.
In the software before I made an interpolation and so I have a pretty ugly contours
I found the filter smooth to adjust the contour but there is some way to smooth also the flow out of the contours? Because if I use Smooth filter also for the 4dflow it smooth also the inside and I don’t want that.
I may misunderstood your question. Contour are usually surfaces so there is no inside.
In case of your previous computation output a contour volume (not surface), you may apply the “Extract Surface” filter to remove the “inside” of this volume. The filter is available in the Filters menu, then Alphabetical.
Thanks for data sharing, I can now understand your problem.
It looks like your have 2 datasets, one with the surface contour and one with points with values. You should merge both before applying the smoothing to get the expected results. I can’t do the merge in ParaView because the two dataset does not have the same number of points. So you may have to do it in your software or manually, for example using VTK python scripting.
