Some results cause PV to crash or hang
I am investigating results gathered through Ansys Fluent in Paraview. I am having some trouble with certain cases where Paraview either crashes when I try to open it, or just seems to load forever.
I am using the Ensight Gold format. For most cases, there are no issues, but I am not sure why for others it causes Paraview to crash. There are minimal geometry changes between the cases.
I cannot share the results because they are sensitive. I have tried different formats like CGNS with no change in behavior. Is there somewhere I can check for an error log? Would anyone have any tips I can do to try and fix this, or any export settings I can try?
Thanks!
Hi @tpalloj
I’m afraid you may not find much help here if you are unable to share your data.
You may want to reach out to Kitware for help: https://www.kitware.com/industry/support/
Best,
Is there a way to share data without having it available to everyone to access?
The purpose of these public discussions is so that the community can benefit. If what you need can’t be shared with everyone then the best option is using Kitware help.
Can you create a different dataset that can be shared?
Alan
I think the main problem is importing the .geo of the Encase Gold results. If I edit the file to exclude all of the scalar exports, it still crashes.
I am trying to find a way to generate an error log to get more info, but I am struggling to find a way to do that.
Turns out the problem was transferring the files through the cloud. Somehow the data was being corrupted in the process. I transferred them manually and the data is behaving as expected now.
