Sparse CSV - Delaunay3D filter Single to Multi threaded
I happen to be using this filter alot and it seems to be single threaded. Is there a way to recompile paraview and utilise multithreading for this?
I am also in need to use this filter with a sparse csv which I would like to pad with 0 in order to be able to use this filter which otherwise simply fails. Is there a good way to do this?
Many thanks
AFAIK, the Delaunay3D filter has no multithreading capability at all.
Thank you for the reply.
Do you also have a recommendation for the second part of my question. It would help alot. here is some sample data.
inox.csv (188.8 KB)
I use table to points and visualise succesfully. I plot a histogram fine as well. But I would like to create a heatmap similar to the delaunay3d filter but due to the low number of points it doesn’t work.
Do you have a reccomendation to plot this data? Can you superimpose it as a heatmap on a second volume?
Many thanks
I’m not sure exactly what you are looking for. But you can map these columns to 3D points and apply Delaunay3D just fine. Please see the attached state file created with ParaView 5.13.0.
inox.pvsm (318.4 KB)
Sorry I am new to this and I am having a few issues.
So I am trying to load the state
and i get this error message
What am I doing wrong?
Ok I pointed it to the file directory and I am getting this
Apart from the mesh quality warning this isnt exactly what I want. I would like to get those coordinates resampled as a population in a wider space and then plot the delauney3d heat map from that.
I’m afraid I don’t understand the request. Could you post something that looks like the heat map you are looking for?
I have shared this previously but this is one example of a structured grid heat map.
from this array which consists of binned values across the range.
and I would like to do something similar with this data here:
which are coordinates of events im interested and somehow generate a similar heatmap as above. perhaps superimposed on to the volume in which this data originates.
Maybe this is a better image
This is the data histogram along one axis. I would like this in 3d over the volume if possible.
Thank you for clarifying. One option:
Point Set to Octree Image produces
It bins points into an image grid that you can then volume render to show density.
Cheers. That’s quite nice. Thanks!
Is there perhaps a way to alter the range and size of the bins perhaps correlated to the volume of origin? Would I need to import that as a mesh of some kind?
