SPH Volume Interpolator Volume Refinement in script
I am using SPH Volume Interpolator, and in Volume refinement, I am trying to change refinement mode to “cell-size” and change the value in a script.
However firstly, tracing doesn’t work here as I commented in this post. Therefore, I cannot exract the statement this way.
Secondly, I tried help function in python shell as below, but was not able to spot anything particularly relevant.
How can I solve this? I need this for my Python script.
>> help(c)
Help on SPHVolumeInterpolator in module paraview.servermanager object:
class SPHVolumeInterpolator(SourceProxy)
 |  SPHVolumeInterpolator(**args)
 |  This filter uses SPH (smooth particle hydrodynamics) kernels to
 |  interpolate a data source onto an input structure. For example, while the
 |  data source is a set of particles, the data from these particles can be
 |  interpolated onto an input volume. Then
 |  the output (which consists of the input structure plus interpolated data)
 |  can then be visualized using classical visualization techniques such as
 |  isocontouring, slicing, heat maps and so on.
 |  Method resolution order:
 |      SourceProxy
 |      Proxy
 |      builtins.object
 |  Methods defined here:
 |  Initialize = aInitialize(self, connection=None, update=True)
 |  Data descriptors defined here:
 |  ComputeShepardSum
 |      Indicate whether to compute the summation of Shepard coefficients. In the
 |      interior of a SPH point cloud, the Shephard summation value should be ~1.0.
 |      Towards the boundary, the Shepard summation is less than 1.0. If ComputeShepardSum
 |      is specified, then the output will contain an array of summed Shepard weights
 |      for each output point.
 |  DensityArray
 |      Specify the density array name.  This is required in computation. If not
 |      specified the code will error out.
 |  DerivativeArrays
 |      Specify the arrays whose derivative is to be taken. If
 |      the name of the array is "derivArray" this will produce an output array
 |      with the name "derivArray_deriv" (after filter execution).
 |  ExcludedArrays
 |      Specify arrays which are to be excluded from the interpolation process.
 |  Input
 |      The data source to be interpolated onto the *Source*.
 |  Kernel
 |  Locator
 |      Specify a point locator.
 |  MassArray
 |      Specify the mass array name.  If not specified, then the mass at each point
 |      will be computed from the density and local (spherical) volume at a each
 |      point.
 |  NullPointsStrategy
 |      Specify a strategy to use when encountering a "null" point during the
 |      interpolation process. Null points occur when the local neighborhood (of
 |      nearby points to interpolate from) is empty. If the strategy is set to
 |      MaskPoints, then an output array is created that marks points as being
 |      valid (=1) or null (invalid =0) (and the NullValue is set as well). If
 |      the strategy is set to NullValue, then the output data value(s) are set
 |      to the NullPoint value (specified in the output point data).
 |  NullValue
 |      Specify the null point value. When a null point is encountered then all
 |      components of each null tuple are set to this value. By default the
 |      null value is set to zero.
 |  PassCellArrays
 |      Indicate whether to shallow copy the input cell data arrays to the output.
 |  PassFieldArrays
 |      Indicate whether to shallow copy the input field data arrays to the output.
 |  PassPointArrays
 |      Indicate whether to shallow copy the input point data arrays to the output.
 |  ShepardSumArrayName
 |      If ComputeShepardSum is on, then an array is generated with name
 |      ShepardSumArrayName for each input point. This vtkFloatArray is placed
 |      into the output of the filter, and NullPoints have value =0.0. The
 |      default name is "Shepard Summation".
 |  Source
 |      The data source that provides the structure to be interpolated on.
 |  ValidPointsMaskArrayName
 |      If the NullPointsStrategy is "Mask Points", then an array is generated for
 |      each input point. This vtkCharArray is placed into the output of the filter,
 |      with a non-zero value for a valid point, and zero otherwise. The name of
 |      this masking array is specified here.
 |  Methods inherited from SourceProxy:
 |  FileNameChanged(self)
 |      Called when the filename of a source proxy is changed.
 |  GetCellDataInformation(self)
 |      Returns the associated cell data information.
 |  GetDataInformation(self, idx=None)
 |      This method returns a DataInformation wrapper around a
 |      vtkPVDataInformation
 |  GetFieldDataInformation(self)
 |  GetPointDataInformation(self)
 |      Returns the associated point data information.
 |  UpdatePipeline(self, time=None)
 |      This method updates the server-side VTK pipeline and the associated
 |      data information. Make sure to update a source to validate the output
 |      meta-data.
 |  UpdatePipelineInformation(self)
 |      This method updates the meta-data of the server-side VTK pipeline and
 |      the associated information properties
 |  __getitem__(self, idx)
 |      Given a slice, int or string, returns the corresponding
 |      output port
 |  Readonly properties inherited from SourceProxy:
 |  CellData
 |      Returns cell data information
 |  FieldData
 |      Returns field data information
 |  PointData
 |      Returns point data information
 |  Methods inherited from Proxy:
 |  GetProperty(self, name)
 |      Given a property name, returns the property object.
 |  GetPropertyValue(self, name)
 |      Returns a scalar for properties with 1 elements, the property
 |      itself for vectors.
 |  InitializeFromProxy(self, aProxy, update=True)
 |      Constructor. Assigns proxy to self.SMProxy, updates the server
 |      object as well as register the proxy in _pyproxies dictionary.
 |  ListProperties(self)
 |      Returns a list of all property names on this proxy.
 |  SetPropertyWithName(self, pname, arg)
 |      Generic method for setting the value of a property.
 |  __del__(self)
 |      Destructor. Cleans up all observers as well as remove
 |      the proxy from the _pyproxies dictionary
 |  __eq__(self, other)
 |      Returns true if the underlying SMProxies are the same.
 |  __getattr__(self, name)
 |      With the exception of a few overloaded methods,
 |      returns the SMProxy method
 |  __hash__(self)
 |      Return hash(self).
 |  __init__(self, **args)
 |      Default constructor. It can be used to initialize properties
 |      by passing keyword arguments where the key is the name of the
 |      property. In addition registrationGroup and registrationName (optional)
 |      can be specified (as keyword arguments) to automatically register
 |      the proxy with the proxy manager.
 |  __iter__(self)
 |      Creates an iterator for the properties.
 |  __ne__(self, other)
 |      Returns false if the underlying SMProxies are the same.
 |  __setattr__(self, name, value)
 |      Implement setattr(self, name, value).
 |  add_attribute(self, name, value)
 |  Data descriptors inherited from Proxy:
 |  __dict__
 |      dictionary for instance variables (if defined)
 |  __weakref__
 |      list of weak references to the object (if defined)
It turns out that in this specific case, the solution was
SPHVolumeInterpolator1.Source.RefinementMode = "Use cell-size"
SPHVolumeInterpolator1.Source.CellSize = (some value)
In more general, when tracing does not work, apparently you need to examine potentially relevant methods to figure out the one.
