My process is as follows:
- Import a group of .vtk data
- Change the Represtation to Volume
- The coloring automatically changes to the data array name (there is only one per file).
- Go to the next time (data) step.
Coloring immediately has a problem:
ERROR: In /builds/gitlab-kitware-sciviz-ci/build/superbuild/paraview/src/VTK/Common/ExecutionModel/vtkCompositeDataPipeline.cxx, line 154
vtkPVDataRepresentationPipeline (0x1a3f7960): Can not execute simple algorithm without output ports
ERROR: In /builds/gitlab-kitware-sciviz-ci/build/superbuild/paraview/src/VTK/Rendering/VolumeOpenGL2/vtkSmartVolumeMapper.cxx, line 279
vtkSmartVolumeMapper (0x18a39a90): Could not find the requested vtkDataArray! 3, 1, -1, data0001
I have used multiple different strategies to avoid this, but can’t seem to get it right. I know the extent of the data but have not found a way to properly create a LUT for this.
my_lut = pv.MakeBlueToRedLT(0, 1)
array_info = reader.PointData[data_array_name]
display1.RescaleTransferFunctionToDataRange(True, False)
AssignLookupTable(array_info, my_lut)
This results in a new error:
File "<string>", line 37, in <module>
File "/home/.../src/animate_data.py", line 73, in prepare_animation
pv.AssignLookupTable(array_info, self.wf_lut)
File ".../ParaView-5.9.1-MPI-Linux-Python3.8-64bit/lib/python3.8/site-packages/paraview/simple.py", line 1761, in AssignLookupTable
if not presets.HasPreset(lutName):
TypeError: HasPreset argument 1: string or None required
Does anyone have an idea to get around the coloring TransferFunction catch22?
