stl file tied to motions time series
Here it goes. I am using 5.10.1
stateForMathieu.pvsm (1.86 MB)
Among Mathieu’s very interesting method, where a point is selected from the bottom of the tower, it seems better to select a center point. Here, the Cell Centers filter is available to obtain the center of the tower bottom. See the following movie.
Hi THanks!
I cannot see the movie…
Is it a problem with the browser you are using? If you right click on the movie, you may be able to save it locally.
Hi @irenerar
I managed to do it, the output of the transform was a bit different that what I thought, you just have to add a AppendAttributes to make it work.
  • Load your state file
  • Click on the extract selection
  • Press Ctrl, keep it pressed and click on Transform
  • Add an append attributes filter, apply
  • Setup the 3DGlyph rep as usual, but using normals_input_1 as orien vector.
hth
Peek 2022-09-19 10-50
Great, thanks a lot again
But I think using CellCenters would also make sense, you still need the normals transform trick though.
