Strange CMake problem when porting from PV 5.12.0 to PV 5.13.1
After successfully compiling the current PV version 5.13.1, I tried to also build my own custom application with that version, but CMake is not able to successfully prepare the project: It tells me after some working: No modules given could be wrapped. This comes out of vtkModuleWrapClientServer.cmake.
Such things are hard to track down, but with tons of message(...) added to the different .cmake files I found out that all my modules end up with one missing header file in the target properties, and in one case where this brings down the number of header files from 1 to 0, the above message is coming.
My tracking efforts ended at a call to add_subdirectory(<source_dir> <binary_dir>), where the first is the source directory of the module and the second the target directory, and all this was or still is working with the code of PV 5.12.0. I can compare this in very much detail because I have now the Release version still with PV 5.12.0 and the Debug version with PV 5.13.1, and after that function call, the module / target ends up with a “headers” property that was not there before, but it contains always one header file ore in the “old” version than in the “new” one. But at this point I am now stuck because I cannot throw message(...) lines into the add_subdirectory function that seems to be “hard coded” into CMake.
The funny thing is that the content of these two directories before the call to add_subdirectory is absolutely identical in both versions, and of course also the CMake version is the same! Only the outcome is different:
  • The PV 5.12.0 version finds all header files that reside in the source directory, plus one header file that is actually in the binary directory
  • The PV 5.13.1 version also finds the headers from the source directory, but not the one in the binary directory
If I read the manual, I actually understand better the second version because nowhere it is written that add_subdirectory should also process files in the binary directory! However, in the first version it obviously does, and only that way it succeeds.
I am afraid that even with this, not even the big experts would be able to figure out what is going on, but maybe somebody has an idea how I could further investigate the “secret activities” that add_subdirectory is doing!?
Could you share the precise error you are getting ?
Right - I just wanted to share some log output when I saw your reply!
The following is some log output that was generated with the PV 5.12.0 version (which so far I kept for the Release variant). You see a lot of stuff that I added inside different .cmake codes using the message() function for tracking.
On top of that I activated the “verbose” option in cmake-gui which generated the “Entering…” and “Returning…” message that seem to be produced by the add_subdirectory function.
The %%% messages were written immediately before (1) and after (2) calling add_subdirectory. During that call, AthosGeoView::AtgDomainsModule is defined as a TARGET (which it is not before), with a headers property that is a list of 6 header files including their full path which are listed in the *** cs_header messages. From this are later derived “client_server_sources” and then “client_server_classes”:
Entering /home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains
===*** going to vtk_module_build AthosGeoView::AtgDomainsModule
%%%*** (1) inside vtk_module_build for AthosGeoView::AtgDomainsModule
%%% module AthosGeoView::AtgDomainsModule not defined yet as a TARGET
%%% adding src dir </home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains/AtgDomainsModule>
%%% adding bin dir </home/cornelis/Main/develop/AthosGeo/Projects/View/Binaries23/Release/Plugins/AtgDomains/AtgDomainsModule>
Entering /home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains/AtgDomainsModule
Returning to /home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains
%%%*** (2) inside vtk_module_build for AthosGeoView::AtgDomainsModule
%%% module AthosGeoView::AtgDomainsModule has 6 headers
===*** done vtk_module_build AthosGeoView::AtgDomainsModule
== module AthosGeoView::AtgDomainsModule has 6 headers
===*** going to vtk_module_wrap_client_server AthosGeoView::AtgDomainsModule
***+++ vtk_module_wrap_client_server
*** cs_modules AthosGeoView::AtgDomainsModule
***+++ _vtk_module_wrap_client_server_library
***+++ _vtk_module_wrap_client_server_sources
*** module AthosGeoView::AtgDomainsModule
*** cs_headers length 6
*** cs_header </home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains/AtgDomainsModule/vtkSMCategoryArraysDomain.h>
*** cs_header </home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains/AtgDomainsModule/vtkSMPitArraysDomain.h>
*** cs_header </home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains/AtgDomainsModule/vtkSMRenameableArraysDomain.h>
*** cs_header </home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains/AtgDomainsModule/vtkSMTonnageArraysDomain.h>
*** cs_header </home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgDomains/AtgDomainsModule/vtkSMCellIdArraysDomain.h>
*** cs_header </home/cornelis/Main/develop/AthosGeo/Projects/View/Binaries23/Release/Plugins/AtgDomains/AtgDomainsModule/AtgDomainsModuleModule.h>
*** cs_sources length 6
*** cs_classes length 6
===*** done vtk_module_wrap_client_server AthosGeoView::AtgDomainsModule
You can see that it finds 5 header files in the “source directory” and one in the “binary directory”.
Now the exactly same thing with PV 5.13.1 for the Debug build of the same code:
***+++ paraview_add_plugin
%%% adding bin dir </home/cornelis/Main/develop/AthosGeo/Projects/View/Binaries23/Debug/Plugins/AtgDomains/AtgDomainsModule>
%%% module AthosGeoView::AtgDomainsModule has 5 headers
== module AthosGeoView::AtgDomainsModule has 5 headers
*** cs_headers length 5
*** cs_sources length 5
*** cs_classes length 5
This module seems to be “accepted” so far, but already here the result is not exactly the same as with the PV 5.12.1 version: The header file in the binary directory is not added, so the total number is only 5 headers found and not 6. And reading the reference for the add_subdirectory function, it should not scan that binary directory - as far as I understand.
The following is the CMakeLists.txt file that add_subdirectory finds in both cases in that subdirectory (source directory):
set(classes
vtkSMCellIdArraysDomain)
vtk_module_add_module(AthosGeoView::AtgDomainsModule
CLASSES
${classes})
# the only purpose of this is to bring the vtk.module file into QtCreator
add_custom_target(AtgDomains_module_spec
SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/vtk.module)
Now the log from the PV 5.13.1 version of the next module that finally terminates with error message (while with PV 5.12.0 it succeeds - with 1 header found in the binary directory and none in the source directory - which is correct):
Entering /home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgPropertyWidgets
===*** going to vtk_module_build AthosGeoView::AtgPropertyWidgetsModule
%%%*** (1) inside vtk_module_build for AthosGeoView::AtgPropertyWidgetsModule
%%% module AthosGeoView::AtgPropertyWidgetsModule not defined yet as a TARGET
%%% adding src dir </home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgPropertyWidgets/AtgPropertyWidgetsModule>
%%% adding bin dir </home/cornelis/Main/develop/AthosGeo/Projects/View/Binaries23/Debug/Plugins/AtgPropertyWidgets/AtgPropertyWidgetsModule>
Entering /home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgPropertyWidgets/AtgPropertyWidgetsModule
Returning to /home/cornelis/Main/develop/AthosGeo/Projects/View/Sources/Plugins/AtgPropertyWidgets
%%%*** (2) inside vtk_module_build for AthosGeoView::AtgPropertyWidgetsModule
%%% module AthosGeoView::AtgPropertyWidgetsModule has 0 headers
===*** done vtk_module_build AthosGeoView::AtgPropertyWidgetsModule
== module AthosGeoView::AtgPropertyWidgetsModule has 0 headers
===*** going to vtk_module_wrap_client_server AthosGeoView::AtgPropertyWidgetsModule
*** cs_modules AthosGeoView::AtgPropertyWidgetsModule
*** module AthosGeoView::AtgPropertyWidgetsModule
*** cs_headers length 0
*** cs_sources length 0
*** cs_classes length 0
*** <AtgPropertyWidgetsModuleCS> is NOT a TARGET
CMake Error at /home/cornelis/Main/develop/ParaView/Binaries/ParaView-v5.13.1/Debug/lib/cmake/paraview-5.13/vtkModuleWrapClientServer.cmake:433 (message):
/home/cornelis/Main/develop/ParaView/Binaries/ParaView-v5.13.1/Debug/lib/cmake/paraview-5.13/ParaViewPlugin.cmake:1284 (vtk_module_wrap_client_server)
Plugins/AtgPropertyWidgets/CMakeLists.txt:123 (paraview_add_plugin)
Configuring incomplete, errors occurred!
And that’s it then for the build based on PV 5.13.1! The CMakeLists.txt file in that second subdirectory is this (all about Qt widgets for the properties panel). Indentation seems to get lost with the “blockquote”:
set(interfaces)
set(sources)
paraview_plugin_add_property_widget(
KIND
WIDGET_DECORATOR
TYPE
“ShowOnlyIfNewAttribute”
CLASS_NAME
atgShowOnlyIfNewAttribute
INTERFACES
property_interfaces
SOURCES
property_sources)
list(APPEND interfaces
${property_interfaces})
list(APPEND sources
${property_sources})
KIND
GROUP_WIDGET
TYPE
“BlockModelParam”
CLASS_NAME
widBlockModelParam
INTERFACES
property_interfaces
SOURCES
property_sources)
list(APPEND sources
KIND
GROUP_WIDGET
TYPE
“CategoryValue”
CLASS_NAME
widCategoryValue
INTERFACES
property_interfaces
SOURCES
property_sources)
list(APPEND sources
KIND
WIDGET
TYPE
“CellArrays”
CLASS_NAME
widCellArrays
INTERFACES
property_interfaces
SOURCES
property_sources)
list(APPEND sources
KIND
GROUP_WIDGET
TYPE
“MultiSelsAndValues”
CLASS_NAME
widMultiSelsAndValues
INTERFACES
property_interfaces
SOURCES
property_sources)
list(APPEND sources
KIND
GROUP_WIDGET
TYPE
“SamplingParam”
CLASS_NAME
widSamplingParam
INTERFACES
property_interfaces
SOURCES
property_sources)
list(APPEND sources
KIND
GROUP_WIDGET
TYPE
“SelectionIds”
CLASS_NAME
widSelectionIds
INTERFACES
property_interfaces
SOURCES
property_sources)
list(APPEND sources
paraview_add_plugin(AtgPropertyWidgets
VERSION
“1.0.0”
SOURCES
${sources}
UI_INTERFACES
${interfaces}
MODULES
MODULE_FILES
AtgPropertyWidgetsModule/vtk.module
MODULE_ARGS
INSTALL_EXPORT AthosGeoView)
add_custom_target(AtgPropertyWidgets_plugin_spec
SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/paraview.plugin)
The reason why I brought both module examples is the fact that even though only the second fails, also the first shows the same “effect”, so it looks like it is really not coming from the fact that this module is all widgets, with auto-generated (“moc’ed”) code etc.
I have now downloaded the entire source code of CMake, in order to find out what may be going on inside the add_subdirectory function that in one case finds a header file that in the other it does not find. Because that header file does exist also in the second (PV 5.13.1) variant!
Looks like diving into the code of add_subdirectory does not deliver much helpful insight: it simply reads the CMakeLists.txt in that subdirectory and executes the commands that are there. Which is for example:
CLASSES
${classes})
Analyzing now this function shows some code where CLASSES are actually treated as if they were SOURCES plus HEADERS. But then - surprise! - another list enters the game that is obviously not part of the above function call: NOWRAP_HEADERS, and this contains then that single header file residing in the binary directory. It appears with full path, while the other headers are just filenames.
Next questions are: a) Where is this NOWRAP_HEADERS coming from? And b) why is it getting lost in one of the two variants?
Answer a) seems to lie in the following piece of code in vtkModule.cmake:
if (NOT _vtk_add_module_HEADER_ONLY AND NOT _vtk_add_module_third_party)
set(_vtk_add_module_generated_header
“${CMAKE_CURRENT_BINARY_DIR}/${_vtk_add_module_module_header_name}”)
list(APPEND _vtk_add_module_NOWRAP_HEADERS
“${_vtk_add_module_generated_header}”)
endif ()
So there it is: the “magic” that brings the binary directory into the game!
Question b) will be for tomorrow…
PS: If you have CMake, you really do not need detective stories any more :slight_smile:
It looks like I have found the bug - and it is within vtkModule.cmake in PV 5.13.1:
set(_vtk_add_module_module_header_name
“${_vtk_add_module_library_name}Module.h”)
“<${_vtk_add_module_generated_header}”)
endif ()
In PV 5.12.0 this looks slightly different:
list(APPEND _vtk_add_module_HEADERS
endif ()
The difference is: in the new version, the “module module header” is appended to the NOWRAP_HEADERS, which has the effect that it is not added to the headers of the module target - which leads after several intermediate steps to the effect that I observed: This header is always missing from the headers list of that module!
However, now it remains to find the location where this change has to be applied in the sources of PV 5.13.1 (because vtkModule.cmake is in the binary tree of the PV build), and finally try if my problem goes indeed away with that change…
Some more explanation: In the following piece of code the actual “attaching” of the headers to the target is happening (in some miraculous way):
set_property(TARGET “${_vtk_add_module_real_target}”
PROPERTY
“INTERFACE_vtk_module_headers” “${_vtk_add_module_headers_build}”)
Immediately before that code, all the list members of _vtk_add_module_HEADERS get their full path prepended, resulting in the list _vtk_add_module_headers_build. However, the list _vtk_add_module_NOWRAP_HEADERS is for the garbage, never ever touched again, and so this “module module header” gets lost (and the above code that appends it to that list has no effect at all).
Bottom line:
  • With the above fix in vtkModule.cmake, my custom ParaView application builds again successfully (with some little adaptations that still need to ensure full compatibility with the new version)
  • I my eyes it is clear that it is a bug in that vtkModule.cmake file and my change is a fix and not just a patch that somehow “saves” a wrong setup in my own project. The strongest indication for this is for me the fact that the wrong statement updates a variable that is afterwards never ever being used, thus just for the garbage
Bad news: At first it looked like the problem is solved, but now it turns out that some more deeper lying problems are present with this version 5.13.1 that I could not really investigate yet.
Yes, the project builds now correctly, and it is possible to start it. But once a plugin needs to be loaded that provides a number of property widgets, Linux terminates with a message that tells me that the required constructor cannot be found in the plugin file:
/home/cornelis/Main/develop/AthosGeo/Projects/Blend/Binaries23/Debug/bin/AthosGeoBlend: symbol lookup error: /home/cornelis/Main/develop/AthosGeo/Projects/Blend/Binaries23/Debug/bin/AtgPropertyWidgets.so: undefined symbol: _ZN16widCategoryValueC1EP10vtkSMProxyP18vtkSMPropertyGroupP7QWidget
Using nm shows that the demangled name of this symbol actually is widCategoryValue::widCategoryValue(vtkSMProxy*, vtkSMPropertyGroup*, QWidget*), and using again nm on the .so file shows that this symbol is somehow there, but of type U - meaning “undefined”. From the fact that in that row there is no entry address I conclude that “undefined” means in this case: the symbol is “defined”, but it points to no binary code or data or whatever.
Bottom line: It looks like there is still more broken in that vtkModule.cmake" than what I have already found - and lacking that kind of “low level” know-how regarding linking etc., I am afraid that even more digging and diving might be the result of this finding.
Next finding: Also in an older, correctly working version of the software the symbols of the widget classes are marked as “U”. However, the plugin has a corresponding .so file that seems to define the “module”: libAtgPropertyWidgetsModule.so, and here the symbols for the actual widgets are defined in the old version, but not in the current one.
From which I conclude that the “undefined” symbols in the plugin library are kind of placeholders for the implementations in the module library.
Interestingly, also in the module library the widget class symbols are visible, but again as “U” without code, while in the older version they are there in a “T” section - meaning: there is some real code.
Bottom line: The question is why the actual code does not make it into the module library, and my current guess is that the many little changes in vtkModule.cmake might be somehow related, but this is so far only a vague guess…
First I would need to understand how the module code is actually supposed to find it’s way into the module library, and then I will have to see where exactly it does not happen any more in the current CMake setup.
Looks like a solution was found - in still another direction than what I initially guessed.
During my internet research also regarding “wrapping”, I came to a 5 years old problem that I had completely forgotten, but at the time it was myself who initiated it: How to ensure that "client-server wrapping is properly initialized"?. So it was partially my own explanations in that thread that brought me back on track also this time! So again I am going to explain the two problems together with their current solutions.
  1. This is the problem that I solved by undoing a little change in vtkModule.cmake, which caused CMake to terminate early due to no headers found for a plugin. This could be solved by simply undoing a change that Ben Boeckel has made about one year ago: https://gitlab.kitware.com/vtk/vtk/-/commit/cf774eac9efcad39ae0893c2fbcfcac561e43abb. From his comment (“There’s nothing wrappable here anyways.”) I conclude that there was no “urgent need” for this step, but simply it looked more logical like that. Which may be true, but I cannot judge this. However, in my case this triggered a side effect in the case of a plugin that had no other headers left then, and via some other steps the vtkModuleWrapClientserver.cmake terminated with the message that I had initially: No modules given could be wrapped. I saw that also for all the other plugins one less header was attached, but whether this would have caused any trouble or not I cannot judge because at the end I could not build anything because of this error!
  2. That same plugin was also in the core of the second problem: Start the successfully built application, generate a “block model” with some specific “source” within my application (…from which I conclude that “regular” plugins with “filters” do actually build AND run…), but on pressing “Apply”, the program crashed with the message that I cited above: symbol not found. Which was the constructor of a property widget class which should have been generated in the “Display” panel. Meaning: a plugin with only property widget code and no “filter” was not correctly built.
It turned out that it was exactly the same plugin that caused already the trouble 5 years ago: the vtkWrapHierarchy seems to be unable to parse headers that refer to Qt widgets, always complaining about “syntax errors” that are not really there, with no way to change the code in such a way that the tool is happy and still also the C++ compiler.
At the time (5 years ago) it turned out that the key lies in the CMakeLists.txt file for the module code to be embedded in the plugin. This was the initially intended way of writing it in that file (with parts omitted that are irrelevant for the problem):
set(classes
  widBlockModelParam
  widCategoryValue
  widCellArrays
  widSamplingParam
  widSelectionIds
vtk_module_add_module(AthosGeoView::AtgPropertyWidgetsModule
  CLASSES
    ${classes}
  SOURCES
But this is is exactly what caused the trouble at that time. The solution was then finally:
set(classes
  widBlockModelParam
  widCategoryValue
  widCellArrays
  widSamplingParam
  widSelectionIds
  SOURCES
    ${classes}
    ${ui_files}
    ${qrc_files}
This worked at the time, but obviously not any more with the current PV version 5.13.1! I saw now that “strange” code, having completely forgotten the reason for it (lack of good commenting…), so I changed it back: I was getting again the error messages from the vtkWrapHierarchy tool that “hates” Qt widget headers. (And after an internet search I hit that old “discourse” thread…)
From this I knew that it is all about the headers, while the sources are required to generate some code at all. The format with class names being passed as SOURCES probably has the effect that for each class, both a .cxx and a .h are added - and as long as the .h files were not added in a HEADERS section (which would be the effect of putting that same list into a CLASSES section), everything went fine with PV 5.12.0.
But not with 5.13.1! However, changing the above to the following at least generated code that did not crash any more:
set(sources
  widBlockModelParam.cxx
  widCategoryValue.cxx
  widCellArrays.cxx
  widMultiSelsAndValues.cxx
  widSamplingParam.cxx
  widSelectionIds.cxx)
  SOURCES
    ${sources}
    ${ui_files}
    ${qrc_files}
Only one little problem remained: The headers disappeared now also from the QtCreator display! But finally with the following also this could be solved:
set(sources
  widCellArrays.cxx
set(private_headers
  atgShowOnlyIfNewAttribute.h
  widBlockModelParam.h
  widCategoryValue.h
  widCellArrays.h
  widMultiSelsAndValues.h
  widSamplingParam.h
  widSelectionIds.h)
  SOURCES
    ${sources}
    ${ui_files}
    ${qrc_files}
  PRIVATE_HEADERS
    ${private_headers}
So basically in some way these widget classes are now “half private” :smile:
Now I learned that I will have to write good comments into my code - and go on testing…
What I know now is the fact that my plugin with property widgets needs “wrapping” only in order to be somehow considered a “proper plugin” that can be loaded and used from other plugins and code. For any decent technical reason, “wrapping” would not be required at all, because these widgets only appear on the client, not on the server side of the application.
And even though it may be true basically what Ben Boeckel is writing: “nothing wrappable there…”, plus the fact that the entire thing also does not need any “wrapping”, changing his code line back to the “unlogical” form that was there before is for me currently the only way to “make it happen” again.
If anybody now can point me to some example or tutorial that tells me how to achieve that without “funny workarounds” I would probably simplify my code accordingly. If not, I am for the moment glad I found some solutions that works “somehow”.
