Strange lines on the isosurface visualisation
I’m not familiar with Fluent or it’s data, so I don’t know if there is an easy way to avoid loading surface data.
An easy way to remove them from the result of Contour is to run it through the Vertex Count filter and then use the Threshold filter to remove any cell with a Vertex Count of less than 3 (which would make it either a line or a point).
