Hi there, I’m trying to produce some magnetic field lines, similar to the ones on this picture:
Obviously I cant really achieve such a wholesome picture:P but for starters I want to achieve the same lenght on magnetic lines, and I think I have the same kind of data (Basically the same simulation code: bhac).
Now, here is the list of Filters. (Ignore the Clip 1, its deactivated whatesoever). I show what I properties added to stream_tracer. But as you can see the lines are “cut” in short way.
I have seen somewhere that Adding Tetrahedralize filter fixes the problem, but If I add it, it crushes.
Even if I add it “manually” on python script, and run it on server. I still get some kind of bad results, although im not completely sure if the steamline is cut or going “downside” of the disk.
Is there a platform to upload the file? You guys use any certain website? (because its large enough, so It will take take, not to choose the wrong upload platform)
