Stream Tracer from vtk
Dear Paraview team,
I run computations with the Telemac-Mascaret solver.
The results are generated in serafin format : so I use a python script provided in the solver package to convert the serafin results in .vtk format and be able to use Paraview.
To date, I can well visualize scalar maps and use Slice, Clip and Contour procedures on any .vtk loaded files. However, I am not able to render streamlines … as the Stream Tracer procedure is not available when .vtk files are loaded.
Please find attached a model of .vtk result I currently use :
r2d_vent00000004.vtk (481.0 KB)
Regards,
Audrey
  • run ParaView
  • Filters β†’ Calculators β†’ "VELOCITY_U______M/S_____________"*iHat+"VELOCITY_V______M/S_____________"*jHat, Apply
  • Filters β†’ StreamTracer β†’ Check Surface Streamline β†’ Apply
Dear Mathieu,
I am so happy … it works perfectly both in 2D and 3D !
Thank you so much !
Audrey
