Hey everyone, I am trying to use streamline representation plugin for my case, I followed the steps from this:
However I only get a black screen… I am modeling two-phase flow in a centrifugal pump btw.
Here is attached photo.
Thanks!
First thing to do would be to update ParaView. 5.7.0 is not a young release anymore…
I cannot since I am working on a cluster… So I am stuck with this version for now… Any other solution? I will try running it locally but if there is a solution other than this it would be much easier rather than copying files here and there! Thanks!
Hi @Qutadah_Rababah ,
It looks like your GPU do not handle the streamlines representation rendering mechanism.
Tbf, this plugin is more a nice trick than an actual in production usage, I’d recommand using the streamlines filters and animations in order to generate images on a cluster.
Best,
Hello, I have made it work, this is the pvsm file for it.
I have added some filters (StreamTracer and Tube) and the plugin is deactivated.
Thanks !
streamlines-foam-vtk-latest.pvsm (1.0 MB)
