StreamTracer
Is it possible to use StreamTracer with vtu extension? I am using Quad for Cell type.
Thank you for your time,
Celso
It is possible. Did you try ? Any error encountered ?
It is definitely possible.
When I open my model, I do not have access to that particular filter. I have attached my file if this helps. Thank you both for a quick reply. ou.vtu (677.1 KB)
Your dataset contains only scalars, not vectors, that is why you can’t use the streamtracer.
That’s it. I grouped them together to make a vector, and it worked… Thank you for the help.
