Should the compilers set at the superbuild level be passed to the individual projects? This does not seem to be the case, at least for las
[~/projects/paraview-superbuild/build-clang-osmesa-5.8.1-rc1]$ cmake "-DCMAKE_CXX_COMPILER:PATH=/usr/bin/clang++" "-DCMAKE_C_COMPILER:PATH=/usr/bin/clang" "-DENABLE_zfp:BOOL=ON" "-DENABLE_tbb:BOOL=ON" "-DENABLE_ospray:BOOL=ON" "-DCMAKE_BUILD_TYPE:STRING=Release" "-DENABLE_netcdf:BOOL=ON" "-DENABLE_visitbridge:BOOL=ON" "-DENABLE_ffmpeg:BOOL=ON" "-DENABLE_qt5:BOOL=OFF" "-DENABLE_mpi:BOOL=ON" "-DUSE_SYSTEM_mpi:BOOL=ON" "-DENABLE_paraview:BOOL=ON" "-DENABLE_xdmf3:BOOL=ON" "-DENABLE_h5py:BOOL=ON" "-DBUILD_SHARED_LIBS:BOOL=ON" "-DENABLE_vtkm:BOOL=OFF" "-DENABLE_gdal:BOOL=ON" "-DENABLE_python:BOOL=ON" "-DENABLE_python3:BOOL=ON" "-DENABLE_numpy:BOOL=ON" "USE_SYSTEM_numpy:BOOL=ON" "-DENABLE_scipy:BOOL=ON" "-DENABLE_matplotlib:BOOL=ON" "-DENABLE_vrpn:BOOL=ON" "-DENABLE_cosmotools:BOOL=ON" "-DENABLE_osmesa:BOOL=ON" "-Dmesa_USE_SWR:BOOL=OFF" "-DENABLE_glu:BOOL=ON" "-DENABLE_tbb:BOOL=OFF" "-DENABLE_boxlib:BOOL=ON" "-DENABLE_silo:BOOL=ON" "-DENABLE_boost:BOOL=ON" "-DENABLE_vortexfinder2:BOOL=OFF" "-DENABLE_las:BOOL=ON" "-DBUILD_TESTING:BOOL=ON" "-DENABLE_adios2:BOOL=ON" "-DENABLE_ospray:BOOL=OFF" "-DENABLE_acusolve:BOOL=ON" "-DENABLE_fontconfig:BOOL=ON" "-DENABLE_bzip2:BOOL=ON" ../src
-- The C compiler identification is Clang 6.0.0
-- The CXX compiler identification is Clang 6.0.0
-- Check for working C compiler: /usr/bin/clang
-- Check for working C compiler: /usr/bin/clang - works
When running:
cmake --build . --target las -j40 I get:
[100%] Performing configure step for 'las'
Not searching for unused variables given on the command line.
-- The C compiler identification is GNU 7.5.0
-- The CXX compiler identification is GNU 7.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc - works
-- Detecting C compiler ABI info
