Using ParaView-4.2.0-RC1-Linux-64bit is all good. The data is attached simple_pipe_flow_surfaceLIC.tgz (74.7 KB)
My machine info
3.10.0-957.12.1.el7.x86_64
CentOS Linux release 7.8.2003
Intel® Xeon® CPU E5-2640 0 @ 2.50GHz
GPU: Titan V 12GB RAM.
The error info is as:
( 106.169s) [paraview ] vtkShaderProgram.cxx:452 ERR| vtkShaderProgram (0x1470ecc0): 1: #version 150
2: #ifdef GL_ES
3: #ifdef GL_FRAGMENT_PRECISION_HIGH
4: precision highp float;
5: precision highp sampler2D;
6: precision highp sampler3D;
7: #else
8: precision mediump float;
9: precision mediump sampler2D;
10: precision mediump sampler3D;
11: #endif
12: #define texelFetchBuffer texelFetch
13: #define texture1D texture
14: #define texture2D texture
15: #define texture3D texture
16: #else // GL_ES
17: #define highp
18: #define mediump
19: #define lowp
20: #if VERSION == 150
21: #define texelFetchBuffer texelFetch
22: #define texture1D texture
23: #define texture2D texture
24: #define texture3D texture
25: #endif
26: #endif // GL_ES
27: #define varying in
28:
29:
30: /*=========================================================================
31:
32: Program: Visualization Toolkit
33: Module: vtkPolyDataFS.glsl
34:
35: Copyright © Ken Martin, Will Schroeder, Bill Lorensen
36: All rights reserved.
37: See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
38:
39: This software is distributed WITHOUT ANY WARRANTY; without even
40: the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
41: PURPOSE. See the above copyright notice for more information.
42:
43: =========================================================================*/
44: // Template for the polydata mappers fragment shader
45:
46: uniform int PrimitiveIDOffset;
47:
48:
49:
50: // VC position of this fragment
51: //VTK::PositionVC::Dec
52:
53: // Camera prop
54: uniform int cameraParallel;
55:
56:
57: // optional color passed in from the vertex shader, vertexColor
58: uniform bool OverridesColor;
59: uniform float ambientIntensity; // the material ambient
60: uniform float diffuseIntensity; // the material diffuse
61: uniform float opacityUniform; // the fragment opacity
62: uniform vec3 ambientColorUniform; // ambient color
63: uniform vec3 diffuseColorUniform; // diffuse color
64: in vec4 vertexColorVSOutput;
65:
66:
67: // optional surface normal declaration
68: //VTK::Normal::Dec
69:
70: // extra lighting parameters
71: uniform vec3 lightColor0;
72: uniform vec3 lightDirectionVC0; // normalized
73: uniform vec3 lightColor1;
74: uniform vec3 lightDirectionVC1; // normalized
75: uniform vec3 lightColor2;
76: uniform vec3 lightDirectionVC2; // normalized
77: uniform vec3 lightColor3;
78: uniform vec3 lightDirectionVC3; // normalized
79: uniform vec3 lightColor4;
80: uniform vec3 lightDirectionVC4; // normalized
81:
82:
83: // Texture maps
84: //VTK::TMap::Dec
85:
86: // Texture coordinates
87: uniform int uMaskOnSurface;
88: uniform mat3 normalMatrix;
89: in vec3 tcoordVCVSOutput;
90:
91: // picking support
92: //VTK::Picking::Dec
93:
94: // Depth Peeling Support
95: //VTK::DepthPeeling::Dec
96:
97: // clipping plane vars
98: //VTK::Clip::Dec
99:
100: // the output of this shader
101: out vec4 fragOutput0;
102: out vec4 fragOutput1;
103: out vec4 fragOutput2;
104:
105:
106: // Apple Bug
107: //VTK::PrimID::Dec
108:
109: // handle coincident offsets
110: uniform float cCValue;
111:
112: // Value raster
113: //VTK::ValuePass::Dec
114:
115: // surface with edges
116: //VTK::Edges::Dec
117:
118: void main()
119: {
120: // VC position of this fragment. This should not branch/return/discard.
121: //VTK::PositionVC::Impl
122:
123: // Place any calls that require uniform flow (e.g. dFdx) here.
124: //VTK::UniformFlow::Impl
125:
126: // Set gl_FragDepth here (gl_FragCoord.z by default)
127: gl_FragDepth = gl_FragCoord.z + cCValue;
128:
129:
130: // Early depth peeling abort:
131: //VTK::DepthPeeling::PreColor
132:
133: // Apple Bug
134: //VTK::PrimID::Impl
135:
136: //VTK::Clip::Impl
137:
138: //VTK::ValuePass::Impl
139:
140: vec3 ambientColor = ambientIntensity * vertexColorVSOutput.rgb;
141: vec3 diffuseColor = diffuseIntensity * vertexColorVSOutput.rgb;
142: float opacity = opacityUniform * vertexColorVSOutput.a;
143: if (OverridesColor) {
144: ambientColor = ambientColorUniform * ambientIntensity;
145: diffuseColor = diffuseColorUniform * diffuseIntensity; }
146:
147:
148: //VTK::Edges::Impl
149:
150: // Generate the normal if we are not passed in one
151: //VTK::Normal::Impl
152:
153: fragOutput0 = vec4(ambientColor + diffuseColor, opacity);
154: //VTK::Light::Impl
155:
156:
157: vec3 tcoordLIC = normalMatrix * tcoordVCVSOutput;
158: vec3 normN = normalize(normalVCVSOutput);
159: float k = dot(tcoordLIC, normN);
160: tcoordLIC = (tcoordLIC - k*normN);
161: fragOutput1 = vec4(tcoordLIC.x, tcoordLIC.y, 0.0 , gl_FragCoord.z);
162: if (uMaskOnSurface == 0)
163: {
164: fragOutput2 = vec4(tcoordVCVSOutput, gl_FragCoord.z);
165: }
166: else
167: {
168: fragOutput2 = vec4(tcoordLIC.x, tcoordLIC.y, 0.0 , gl_FragCoord.z);
169: }
170:
171:
172: if (fragOutput0.a <= 0.0)
173: {
174: discard;
175: }
176:
177: //VTK::DepthPeeling::Impl
178:
179: //VTK::Picking::Impl
180:
181: // handle coincident offsets
182: //VTK::Coincident::Impl
183: }
( 106.180s) [paraview ] vtkShaderProgram.cxx:453 ERR| vtkShaderProgram (0x1470ecc0): 0(158) : error C1503: undefined variable “normalVCVSOutput”
Loguru caught a signal: SIGSEGV
Stack trace:
47 0x407b6d /old_u/ychen/Downloads/ParaView-5.8.1-MPI-Linux-Python2.7-64bit/bin/paraview() [0x407b6d]
46 0x2aef61209555 __libc_start_main + 245
45 0x4077fd /old_u/ychen/Downloads/ParaView-5.8.1-MPI-Linux-Python2.7-64bit/bin/paraview() [0x4077fd]
44 0x2aef639770b4 QCoreApplication::exec() + 132
43 0x2aef6396e4aa QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 234
42 0x2aef99954e8d /old_u/ychen/Downloads/ParaView-5.8.1-MPI-Linux-Python2.7-64bit/plugins/platforms/…/…/lib/libQt5XcbQpa.so.5(+0xb1e8d) [0x2aef99954e8d]
41 0x2aef639c226a QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag) + 1114
40 0x2aef639c428e QTimerInfoList::activateTimers() + 1118
39 0x2aef6396fc08 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 264
38 0x2aef61bc4f01 QApplication::notify(QObject*, QEvent*) + 577
37 0x2aef61bbdc8c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
36 0x2aef6399cb7b QObject::event(QEvent*) + 123
35 0x2aef639a8838 QTimer::timerEvent(QTimerEvent*) + 40
34 0x2aef639a8557 QTimer::timeout(QTimer::QPrivateSignal) + 39
33 0x2aef6399bc47 QMetaObject::activate(QObject*, int, int, void**) + 1511
32 0x2aef62b42325 /old_u/ychen/Downloads/ParaView-5.8.1-MPI-Linux-Python2.7-64bit/bin/…/lib/libpqCore-pv5.8.so.1(+0x76325) [0x2aef62b42325]
31 0x2aef62c0fc92 pqView::forceRender() + 114
30 0x2aef6e72a708 vtkSMViewProxy::StillRender() + 328
29 0x2aef64453b95 vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 53
28 0x2aef64454adb vtkPVSessionCore::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 59
27 0x2aef64454ca5 vtkPVSessionCore::ExecuteStreamInternal(vtkClientServerStream const&, bool) + 245
26 0x2aef64faeded vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) + 29
25 0x2aef64faeabe vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) + 1198
24 0x2aef64fadffa vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) + 330
23 0x2aef64fadd05 vtkClientServerInterpreter::CallCommandFunction(char const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) + 325
22 0x2aef6c7c06c0 vtkPVRenderViewCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) + 7456
21 0x2aef6e69592f vtkPVRenderView::StillRender() + 95
20 0x2aef6e6a0797 vtkPVRenderView::Render(bool, bool) + 1623
19 0x2aef6651a270 vtkGenericOpenGLRenderWindow::Render() + 144
18 0x2aef66599d2d vtkOpenGLRenderWindow::Render() + 13
17 0x2aef67b9c52b vtkRenderWindow::Render() + 251
16 0x2aef67b9bf15 vtkRenderWindow::DoStereoRender() + 197
15 0x2aef67bad055 vtkRendererCollection::Render() + 197
14 0x2aef67ba71d7 vtkRenderer::Render() + 1991
13 0x2aef6659c35b vtkOpenGLRenderer::DeviceRender() + 187
12 0x2aef664f32f6 vtkCameraPass::Render(vtkRenderState const*) + 534
11 0x2aef6659e491 vtkOpenGLRenderer::UpdateGeometry(vtkFrameBufferObjectBase*) + 2049
10 0x2aef665a0c31 vtkOpenGLRenderer::DeviceRenderOpaqueGeometry(vtkFrameBufferObjectBase*) + 33
9 0x2aef67ba5216 vtkRenderer::DeviceRenderOpaqueGeometry(vtkFrameBufferObjectBase*) + 86
8 0x2aef6e678c4e vtkPVLODActor::RenderOpaqueGeometry(vtkViewport*) + 78
7 0x2aef6e679680 vtkPVLODActor::Render(vtkRenderer*, vtkMapper*) + 384
6 0x2aef6651d9ae vtkOpenGLActor::Render(vtkRenderer*, vtkMapper*) + 158
5 0x2aef7b8d0aec vtkCompositeSurfaceLICMapper::Render(vtkRenderer*, vtkActor*) + 972
4 0x2aef664fcd74 vtkCompositePolyDataMapper2::Render(vtkRenderer*, vtkActor*) + 4164
3 0x2aef664f626e vtkCompositeMapperHelper2::RenderPieceDraw(vtkRenderer*, vtkActor*) + 206
2 0x2aef664f5f31 vtkCompositeMapperHelper2::DrawIBO(vtkRenderer*, vtkActor*, int, vtkOpenGLHelper&, unsigned int, int) + 113
1 0x2aef66578835 vtkOpenGLPolyDataMapper::UpdateShaders(vtkOpenGLHelper&, vtkRenderer*, vtkActor*) + 1173
0 0x2aef6121d400 /lib64/libc.so.6(+0x36400) [0x2aef6121d400]
( 106.180s) [paraview ] :0 FATL| Signal: SIGSEGV
