I recently enabled the “Surface LIC” plugin for streamline-like visualizations. When I select Surface LIC after loading the data in Paraview, it works fine. However, when I try to get a slice on this 3D (geometry) represantation, Paraview crashes almost instantly. I also tried applying the slice first, then Surface LIC, but had no luck.
Hi again, latest “nightly” seems to be working for now, thanks.
Ultimately, I want to visualize the streamlines on 2D plane based on YZ (mean) velocities (on X plane). I defined the velocity (sqrt(y^2 +z^2)) using the calculator, and plotted the Surface LIC with the new velocity as vector (under Surface LIC:Integrator). The result is nothing close to what I was expecting, its full of with tiny swirl-like patterns. Am I doing something wrong?
