SurfaceLic crash on 2D .vtu in ParaView 5.8.0 and 5.8.1
The same data resampled to .vit works fine.
On ParaView 5.6.0 and 5.7.0, it renders correctly, but prints this error message:
ERROR: In /Users/kitware/dashboards/buildbot-slave/a64f5607/build/superbuild/paraview/src/VTK/Rendering/OpenGL2/vtkShaderProgram.cxx, line 462
vtkShaderProgram (0x600003ca6760): 1: #version 150
2: #ifdef GL_ES
3: #ifdef GL_FRAGMENT_PRECISION_HIGH
4: precision highp float;
5: precision highp sampler2D;
6: precision highp sampler3D;
7: #else
8: precision mediump float;
9: precision mediump sampler2D;
10: precision mediump sampler3D;
11: #endif
12: #define texelFetchBuffer texelFetch
13: #define texture1D texture
14: #define texture2D texture
15: #define texture3D texture
16: #else // GL_ES
17: #define highp
18: #define mediump
19: #define lowp
20: #if VERSION == 150
21: #define texelFetchBuffer texelFetch
22: #define texture1D texture
23: #define texture2D texture
24: #define texture3D texture
25: #endif
26: #endif // GL_ES
27: #define varying in
28:
29:
30: /=========================================================================
31:
32: Program: Visualization Toolkit
33: Module: vtkPolyDataFS.glsl
34:
35: Copyright © Ken Martin, Will Schroeder, Bill Lorensen
36: All rights reserved.
37: See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
38:
39: This software is distributed WITHOUT ANY WARRANTY; without even
40: the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
41: PURPOSE. See the above copyright notice for more information.
42:
43: =========================================================================
44: // Template for the polydata mappers fragment shader
45:
46: uniform int PrimitiveIDOffset;
47:
48:
49:
50: // VC position of this fragment
51: //VTK::PositionVC::Dec
52:
53: // Camera prop
54: uniform int cameraParallel;
55:
56:
57: // optional color passed in from the vertex shader, vertexColor
58: uniform bool OverridesColor;
59: uniform float ambientIntensity; // the material ambient
60: uniform float diffuseIntensity; // the material diffuse
61: uniform float opacityUniform; // the fragment opacity
62: uniform vec3 ambientColorUniform; // ambient color
63: uniform vec3 diffuseColorUniform; // diffuse color
64: in vec4 vertexColorVSOutput;
65:
66:
67: // optional surface normal declaration
68: //VTK::Normal::Dec
69:
70: // extra lighting parameters
71: uniform vec3 lightColor0;
72: uniform vec3 lightDirectionVC0; // normalized
73: uniform vec3 lightColor1;
74: uniform vec3 lightDirectionVC1; // normalized
75: uniform vec3 lightColor2;
76: uniform vec3 lightDirectionVC2; // normalized
77: uniform vec3 lightColor3;
78: uniform vec3 lightDirectionVC3; // normalized
79: uniform vec3 lightColor4;
80: uniform vec3 lightDirectionVC4; // normalized
81:
82:
83: // Texture maps
84: //VTK::TMap::Dec
85:
86: // Texture coordinates
87: uniform int uMaskOnSurface;
88: uniform mat3 normalMatrix;
89: in vec3 tcoordVCVSOutput;
90:
91: // picking support
92: //VTK::Picking::Dec
93:
94: // Depth Peeling Support
95: //VTK::DepthPeeling::Dec
96:
97: // clipping plane vars
98: //VTK::Clip::Dec
99:
100: // the output of this shader
101: out vec4 fragOutput0;
102: out vec4 fragOutput1;
103: out vec4 fragOutput2;
104:
105:
106: // Apple Bug
107: //VTK::PrimID::Dec
108:
109: // handle coincident offsets
110: uniform float cCValue;
111:
112: // Value raster
113: //VTK::ValuePass::Dec
114:
115: void main()
116: {
117: // VC position of this fragment. This should not branch/return/discard.
118: //VTK::PositionVC::Impl
119:
120: // Place any calls that require uniform flow (e.g. dFdx) here.
121: //VTK::UniformFlow::Impl
122:
123: // Set gl_FragDepth here (gl_FragCoord.z by default)
124: gl_FragDepth = gl_FragCoord.z + cCValue;
125:
126:
127: // Early depth peeling abort:
128: //VTK::DepthPeeling::PreColor
129:
130: // Apple Bug
131: //VTK::PrimID::Impl
132:
133: //VTK::Clip::Impl
134:
135: //VTK::ValuePass::Impl
136:
137: vec3 ambientColor = ambientIntensity * vertexColorVSOutput.rgb;
138: vec3 diffuseColor = diffuseIntensity * vertexColorVSOutput.rgb;
139: float opacity = opacityUniform * vertexColorVSOutput.a;
140: if (OverridesColor) {
141: ambientColor = ambientColorUniform * ambientIntensity;
142: diffuseColor = diffuseColorUniform * diffuseIntensity; }
143:
144:
145: // Generate the normal if we are not passed in one
146: //VTK::Normal::Impl
147:
148: fragOutput0 = vec4(ambientColor + diffuseColor, opacity);
149: //VTK::Light::Impl
150:
151:
152: vec3 tcoordLIC = normalMatrix * tcoordVCVSOutput;
153: vec3 normN = normalize(normalVCVSOutput);
154: float k = dot(tcoordLIC, normN);
155: tcoordLIC = (tcoordLIC - k*normN);
156: fragOutput1 = vec4(tcoordLIC.x, tcoordLIC.y, 0.0 , gl_FragCoord.z);
157: if (uMaskOnSurface == 0)
158: {
159: fragOutput2 = vec4(tcoordVCVSOutput, gl_FragCoord.z);
160: }
161: else
162: {
163: fragOutput2 = vec4(tcoordLIC.x, tcoordLIC.y, 0.0 , gl_FragCoord.z);
164: }
165:
166:
167: if (fragOutput0.a <= 0.0)
168: {
169: discard;
170: }
171:
172: //VTK::DepthPeeling::Impl
173:
174: //VTK::Picking::Impl
175:
176: // handle coincident offsets
177: //VTK::Coincident::Impl
178: }
ERROR: In /Users/kitware/dashboards/buildbot-slave/a64f5607/build/superbuild/paraview/src/VTK/Rendering/OpenGL2/vtkShaderProgram.cxx, line 463
vtkShaderProgram (0x600003ca6760): ERROR: 0:153: Use of undeclared identifier ‘normalVCVSOutput’
ERROR: 0:154: Use of undeclared identifier ‘normN’
ERROR: 0:155: Use of undeclared identifier ‘k’
ERROR: 0:155: Use of undeclared identifier ‘normN’
Hi Roxana,
Can you share the failing data ?
Yes, I can. What is the best way do that?
Either directly in discourse if the data is small, or through a file sharing website like wetransfer or google drive if it is big.
vel_mesh20point.vtk (239.9 KB)
Here it is :slight_smile:
I’m quite sure it has been fixed in master already. Can you try it ?
I see. I currently only have the binary version. So it will take a moment.
Yes, I can confirm the crash does not occur in paraview 5.8.1 checked out today from master.
