Switch off dark mode in 6.0?
I just installed 6.0 on PC and found that it has defaulted to a ‘dark mode’ UI, and I really want to switch back to the light mode that I had in version 5.x. I cannot find a way to do this in the settings, how can I get light mode back?
Just curious - is your window system in dark mode? Which OS are you on?
Windows 10, dark mode. Paraview 5.x doesn’t default to dark mode though.
You can keep windows in Dark mode and change all your “apps” in light mode if thats helps:
This is not ideal though, a more fine grained control would be nice.
Thanks, I tried that and it changes way too many parts of windows back to light mode. For the time being I’ve managed to get it to override the stylesheet somewhat with a .bat file and qss file so that at least it’s light in colour, though the buttons sizes get a bit messed up. If it’s possible to request features then I’d love a dark/light theme toggle!
Can you share how you did it? That would be great!
No problem. I put this in a .bat file (paraview_light.bat) in the Paraview bin folder:
@echo off
setlocal
set "APPDIR=%~dp0"
set "EXE=%APPDIR%paraview.exe"
set "QSS=%APPDIR%light.qss"
REM Force a light Qt style; stylesheet makes it lighter.
set "QT_STYLE_OVERRIDE=Fusion"
REM Launch ParaView with the stylesheet from the same folder
"%EXE%" -style Fusion -stylesheet "%QSS%" %*
endlocal
The Fusion stylesheet was the first attempt, which wasn’t successful, so that line can probably be removed. I added a style sheet in the same bin folder (light.qss). I don’t know much about style sheets unfortunately, so this is mostly the work of AI. I imagine that it took a pretty wild stab in the dark and has probably tried to apply styles to things that don’t even exist in the Paraview UI, but it worked well enough that I was at least able to use 6.0:
/* Very light, neutral UI */
QWidget { background: #f6f6f6; color: #111; }
QMenuBar, QMenu, QToolBar, QStatusBar, QDockWidget { background: #efefef; color: #111; }
QToolTip { background: #ffffdc; color: #111; border: 1px solid #c0c0c0; }
/* Editors, views */
QLineEdit, QTextEdit, QPlainTextEdit,
QListView, QTreeView, QTableView {
  background: #ffffff; color: #111; selection-background-color: #cde7ff; selection-color: #111;
/* Headers */
QHeaderView::section {
  background: #e9e9e9; color: #111; padding: 3px; border: 1px solid #d0d0d0;
/* Buttons & controls */
QPushButton, QToolButton, QComboBox, QSpinBox, QDoubleSpinBox {
  background: #f9f9f9; color: #111; border: 1px solid #cfcfcf; padding: 4px 6px;
QPushButton:hover, QToolButton:hover, QComboBox:hover {
QPushButton:pressed, QToolButton:pressed {
  background: #e6e6e6;
/* Tabs */
QTabBar::tab {
  background: #eaeaea; color: #111; padding: 6px 10px; border: 1px solid #d0d0d0;
QTabBar::tab:selected { background: #ffffff; }
/* Splitters */
QSplitter::handle { background: #dddddd; }
/* Checkboxes / radios */
QCheckBox, QRadioButton { background: transparent; color: #111; }
/* Scrollbars (simple light) */
QScrollBar:vertical, QScrollBar:horizontal {
  background: #f0f0f0; border: 1px solid #d0d0d0;
QScrollBar::handle:vertical, QScrollBar::handle:horizontal {
  background: #cfcfcf; min-height: 20px; min-width: 20px;
/* --- Toolbar icon sizing --- */
/* Main window toolbars (keep these a bit larger) */
QMainWindow > QToolBar { qproperty-iconSize: 18px; }
/* Render-view toolbars INSIDE the VTK widget (make these smaller) */
/* Cover common widget class names across ParaView builds */
QVTKOpenGLNativeWidget QToolBar,
QVTKOpenGLWidget QToolBar,
pqQVTKWidget QToolBar {
  qproperty-iconSize: 14px;
/* Tighten padding on those smaller buttons */
QVTKOpenGLNativeWidget QToolBar QToolButton,
QVTKOpenGLWidget QToolBar QToolButton,
pqQVTKWidget QToolBar QToolButton {
  padding: 2px;
/* (Optional) smaller dock titlebar buttons */
QDockWidget::close-button, QDockWidget::float-button { icon-size: 10px; }
Thanks for sharing, I’ll try it out.
The cleanest solution is to create an environment variable as explained here: 6.1: how to get rid of the dark theme? - #13 by Eastwave
