Dear all,
OS Name: Ubuntu 20.04.4
I installed Paraview by downloading in the official website and also installed openmpi.
After that, I meet this issue when type paraview in the terminal. Before installing the openmpi, I was able to use the Paraview without any problem.
Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyparaview: symbol lookup error: /usr/local/lib/openmpi/mca_coll_han.so: undefined symbol: mca_coll_base_colltype_to_str
What can I do to address this issue?
mwestphal
(Mathieu Westphal (Kitware))
2
That is unexpected, does the issue goes away if you remove openmpi ?
Thanks for your quick reply. I will try your suggestion!
Good. it’s working. I went to the fold that I downloaded and entered below.
sudo make all uninstall
Then I restarted the terminal and typed the paraview. it’s working!
I referred this site:[OMPI users] Unistall open-mpi
Thanks a lot!
ben.boeckel
(Ben Boeckel (Kitware))
5
This is because our binaries use MPICH. OpenMPI is not ABI-compatible, so it cannot be found by something like LD_LIBRARY_PATH when using ParaView.
