cessenat
(Olivier Cessenat)
February 19, 2024, 6:35pm
1
The “Tesselate” filter applied on “VTK_POLYGON” indicates “Input dataset has cells without parametization”. Example file:
# vtk DataFile Version 3.0
Generated by Hand
ASCII
DATASET UNSTRUCTURED_GRID
POINTS 14 double
0.0 0.0 0.001
0.0 0.0 0.002 1.0 0.0 0.0
1.0 1.0 0.0 0.0 1.0 0.0
2.0 0.0 0.0 2.0 1.0 0.0
0.5 0.1 0.0 1.0 0.6 0.0
0.6 1.1 0.0 0.1 0.4 0.0
2.0 -0.5 0.0 1.0 -1.0 0.0
0.0 -0.6 0.0
CELLS 2 12
4 2 5 6 3
6 1 13 12 11 5 2
CELL_TYPES 2
9
7
POINT_DATA 14
FIELD FieldData 1
TempNode 1 14 float
0.0
0.0 1.5
0.2 0.0
1.0 0.4
2.0 0.5
0.25 0.15
0.25 0.45
0.13
mwestphal
(Mathieu Westphal (Kitware))
February 20, 2024, 9:45am
2
Use Triangulate filter before using Tesselate.
cessenat
(Olivier Cessenat)
February 21, 2024, 9:37am
3
The “Triangulate” filtre is grey’ed (not applicable) on my Ubuntu 22.04 Paraview 5.10.0-RC1.
Example below, even with a simple quad.
Generated by Hand
ASCII
POINTS 4 double
1.0 0.0 0.0 2.0 0.0 0.0 2.0 1.0 0.0 1.0 1.0 0.0
CELLS 1 5
4 1 2 3 0
CELL_TYPES 1
9
POINT_DATA 4
FIELD FieldData 1
TempNode 1 4 float
1.5 1.0 2.0 0.5
mwestphal
February 21, 2024, 10:05am
4
Use “ExtractSurface” first if you want to work with surface, or use “Tetrahedralize” instead.
cessenat
(Olivier Cessenat)
February 21, 2024, 11:21am
5
OK thanks. But it cannot be applied on quadratic elements at the same time.
cessenat
(Olivier Cessenat)
February 21, 2024, 4:56pm
7
Generated by Hand
ASCII
POINTS 21 double
0.0 0.0 0.001
0.0 -0.6 0.0 -1.0 0.0 0.0
-0.5 0.5 0.0 -0.5 0.0 0.0
2.5 0.0 0.0 2.3 0.8 0.0
2.4 1.5 0.0 1.9 1.5 0.0
CELLS 5 35
8 1 2 3 4 7 8 9 10
4 2 5 6 3
6 1 13 12 11 5 2
6 4 14 1 15 16 10
6 5 17 18 19 20 6
CELL_TYPES 5
23
9
7
22
7
CELL_DATA 5
SCALARS material int
LOOKUP_TABLE default
1
2 2 2
3
FIELD FieldData 1
TempCell 1 5 float
0.0
0.4 0.1 0.2
0.3
POINT_DATA 21
FIELD FieldData 1
TempNode 1 21 float
0.0
0.0 1.5 0.2 0.0 1.0
0.4 2.0 0.5 0.25 0.15
0.25 0.45 0.13 0.21 0.41
0.17 0.23 0.45 0.06 0.28
mwestphal
February 21, 2024, 5:00pm
8
Tetrahedralize + Tesselate works fine on your data:
dcthomp
(David Thompson (Kitware))
February 21, 2024, 5:15pm
9
Yes, but I think the point is that that Tetrahedralize (or ExtractSurface + Triangulate) do not offer an option for how finely to subdivide higher-order cells, so you are always left with a coarse subdivision for higher-order cells should you need to triangulate polygons.
I don’t know how much work it would take to provide a “non-linear subdivision level” to the Tetrahedralize and Triangulate filters.
cessenat
(Olivier Cessenat)
February 21, 2024, 5:24pm
10
That’s the point.
Initially, I thought the Tesselate operator, that works on triangles and quads, could also apply on polygons.
