texture Mapper 3D
every i open new file to visualize i always got this comment
Generic Warning: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/Rendering/VolumeOpenGL/vtkOpenGLVolumeTextureMapper3D.cxx, line 57
vtkOpenGLVolumeTextureMapper3D::vtkOpenGLVolumeTextureMapper3D was deprecated for VTK 7.0 and will be removed in a future version.
how to fix this?
This is just a warning and can be safely ignored.
Hi again, I have the same problem but when i ignore that messages i cant see the my solution, i onlz see solid color . How can i fix it? thanks beforehand
You issue is unrelated to the message. You have to select the array you want to color your data with.
Peek%202019-07-17%2011-52
Thanks sir, i mean i cant get my results. When i want to change solid color i only see 4 options as namely cellNormals, VtkCompositeindex, CasePath,Vtkblockcolors
Can you share your dataset ?
Which format are you using ?
OpenFoam 2.3.0
Paraview 5.4.1
i am new user in OpenFoam i tried to fix this problem but i cant get any solution.
Thanks for your reply
When you open your OpenFOAM file, are all the arrays selected ?
Can you share your information tab ?
in down side there is nothing like values (u,p)image
Well, there is no arrays in your data. You need to figure out why.
G10000.vtu (804.1 KB)
hi i already make fine grid ant there is no command error
but i can not visualize in paraview.
any sugggest
Does anyone know how to ignore this message? I am using Ubuntu 18.04, everytime I open a .tec file I receive this annoying message.
Upgrade your version of ParaView.
For any further question, open your own topic.
