The screen display of paraview is strange.
Hello, Everyone.
I have used paraview 5.6.0 for about one year. The other day, paraview was suddnly crashed. After that, the screen display green line like picture.
This problem doesn’t occur in other software on my PC. This problem occurs when I use paraview.
Paraview function such as opening file and filter works correctly, but only display doesn’t work well.
I tried reinstall paraview, but problem is not solved.
I also tried the other version of paraview, 5.8.0 and 5.6.1. In version 5.6.1, same problem occur. In version 5.8.0, problem doesn’t occur.
But I want to use version 5.6, because my PC freezes in version 5.8 when I try to get data via pvserver.
Could you help me to solve the problem?
That’s a new one.
Please share :
OS
GPU
GPU driver version
Any other oddities like VM, special windows managers…
Thank you for replying.
OS: windows10 Home(version 1903)
GPU: Intel® UHD Graphics 620
GPU driver: version 27.20.100.8280
I done’t think that I use special environment.
Thank you
That may be a new version of :
Can you try the different solution proposed there ?
I disabled my GPU driver and restarted paraview. As the results, green line disappeared. So, the cause of problem should be my GPU.
Then, I try to use different version of GPU driver.
Thank you for helping.
