If i have a temperature and a velocity field, it is possible to calculate the PPD and PMV index? I searched in filters but I did not find a dedicated filter to thermal comfort. Is there a plugin or extension that I can install?
The formula to calculate the indexes requires temperature, velocity, some input constant and 2 iterative processes.
thanks for the asnwer
yes it can be computed node by node.
In python calculator can I insert a code of 60 lines with for and if cycles and with input parameters?
if there is not a existing filter or extension, it is the only way
