Through some sort of unknown manipulation, I’ve ended up with a PVSM that always produces a the default blue background when saving a screenshot, even when I select the WhiteBackground option.
I noted that if I recreated the render view from scratch, it will go away for a bit before coming back. I suspect it might be because I use a screenshotting python script that does the following, but I cannot reproduce it, so maybe it’s a red herring.
for t in ts:
print("processing {}".format(t))
view.ViewTime = t
# Hide, Show here..
view.Update()
SaveScreenshot(
os.path.join(basedir, "{}.png".format(int(view.ViewTime))),
view,
ImageResolution=[1280, 720],
OverrideColorPalette="WhiteBackground"
Luckily, I’ve figured out that if I deleted all of my filters/sources in the pipeline after creating this renderview and save the resulting PVSM, it will still consistently screenshot only a blue background and I’ve attached it here: always-blue.pvsm (1.2 MB). What am I doing wrong here?
