I would like to threshold by part ID, however I see that one can only do so by point/cell data scalars.
Is there a way to convert field array data (part IDs) to cell arrays?
Thanks,
Theodore
Thanks,
Theodore
If your data is a multiblock dataset, the easiest way to do it may be to use the Block Scalars filter.
I see that this filter adds a scalar field, but one that only pertains to block indices. I’m looking for a way to get a scalar field that relates directly to part IDs.
I understand that I could build and append a partID cell data array to each of my lowest level blocks through a programmable filter.
Alternatively, I will probably attach a partID array to my data as it is written. It’s coming out of a custom solver.
Thank you for your suggestion, though.
