Threshold exactly one cell
I would like to threshold exactly one element of a mesh based on a cell data attribute (the element having maximum or minimum value). Is there a way to do that?
The easiest way to extract the cell with the maximum (or minimum) value is to use Find Data Screenshot 2025-01-24 at 2.11.27 PM (about the middle of the top toolbar or in the Edit menu). Create a selection criterea of Cell element types and where the field is max (or is min).
After you click Find Data button, the element will be highlighted in the 3D view and will be listed in the find data dialog. After that, you can add the Extract Selection filter Screenshot 2025-01-24 at 2.16.19 PM. Your selection of the maximum (minimum) element will be copied to its parameters, and when you Apply it, your element will be extracted.
