I have a PolyVertex dataset that has an integer as a value on each vertex. For a simplified test case, here is a file that demonstrates my issue:
# vtk DataFile Version 1.0
Cube example
ASCII
DATASET POLYDATA
POINTS 8 float
0.0 0.0 0.0
1.0 0.0 0.0
1.0 1.0 0.0
0.0 1.0 0.0
0.0 0.0 1.0
1.0 0.0 1.0
1.0 1.0 1.0
0.0 1.0 1.0
POLYGONS 6 30
4 0 1 2 3
4 4 5 6 7
4 0 1 5 4
4 2 3 7 6
4 0 4 7 3
4 1 2 6 5
POINT_DATA 8
SCALARS my_scalars int
LOOKUP_TABLE custom_table
1
1
1
1
2
2
3
3
LOOKUP_TABLE custom_table 8
0.0 0.0 0.0 1.0
1.0 0.0 0.0 1.0
0.0 1.0 0.0 1.0
1.0 1.0 0.0 1.0
0.0 0.0 1.0 1.0
1.0 0.0 1.0 1.0
0.0 1.0 1.0 1.0
1.0 1.0 1.0 1.0
I load this into ParaView and see the data. I can hover over the vertices and see the correct values. All is well and good. I apply the “Threshold” filter (via the toolbar button) and select the “my_scalars” and select 3 as the lower and upper bound. Click the apply button. nothing shows up in ParaView. I would have thought that I would have seen 2 vertices showing. I have the vertex size cranked up to 20 and I use “Points” as my representation. If I use 2 as the lower and 3 as the upper I will now see 4 points. So my question is: Why when I use 3 as my upper and lower bound for the threshold do I not see any vertices at all? This is with version 5.10.1 on macOS and Windows.
Thanks
Mike Jackson
