I have about 50 different vtk files, that each represent boreholes in space. Can I add an individual title, on top of each vtk (probably that scales with x-axis label etc), so I can see what is what?
Best
Best
In a 3D view or chart view ?
3D view
This is doable with a 3D Text source but definitely not practical. YOu may want to try to see how it goes for you?.
Thanks, I will give it a try. Can you provide a legacy vtk file format, how will this 3d text source will look like?
Best
Maybe look at doing it through a selection and displaying the point or cell labels in the Selection Display Inspector. You’d have to add either a point data or cell data string array with the label you want.
Thanks for the help. I have thousands of legacy vtk files (which I make by myself). So, I don’t want to do this writing one-by-one. Even if i have to generate separate 3d text source vtk, for each file I have.
If possible I am asking that the “Test” you how in the figure, can be loaded from a vtk file.
How this will look like.
No, as I said that solution would have to be manual.
Ok, I see. I did generate a vtk file, but it seems that each letter is actually a polygon.
How I see the solution is to generate a vtk file per letter, and then combine then to make sentences.
I hope there will be an easier solution, but thanks anyway.
