I have the same issue, but nothing suggested here works:
here’s my setup:
- i build paraview from git repo (tag v5.9.1)
- i use a “global” python3.8 on my laptop (all paths to other pythons are deleted from my ~.bashrc, this is ubuntu 20.4), so that in paraview’s console i get:
Python 3.8.10 (default, Mar 15 2022, 12:22:08)
[GCC 9.4.0] on linux
>>> from paraview.simple import *
>>> import sys
>>> sys.path
['/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages', '/home/gosia', '/usr/local/lib/python3.8/site-packages', '/usr/lib/python38.zip', '/usr/lib/python3.8', '/usr/lib/python3.8/lib-dynload', '/home/gosia/.local/lib/python3.8/site-packages', '/usr/local/lib/python3.8/dist-packages', '/usr/lib/python3/dist-packages']
- at the same time i get the following error messages in the terminal, from which i start paraview:
raceback (most recent call last):
File "/usr/lib/python3.8/code.py", line 90, in runcode
exec(code, self.locals)
File "<console>", line 1, in <module>
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/simple.py", line 41, in <module>
from paraview import servermanager
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/servermanager.py", line 3401, in <module>
__initialize()
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/servermanager.py", line 3392, in __initialize
c = Connection(iter.GetCurrentSessionId(), iter.GetCurrentSession())
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/servermanager.py", line 2067, in __init__
_createModules(self.Modules)
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/servermanager.py", line 2728, in _createModules
m.filters = createModule('filters')
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/servermanager.py", line 2842, in createModule
cobj = _createClass(groupName, proxyName, apxm=pxm)
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/servermanager.py", line 2799, in _createClass
cdict.update(_createClassProperties(proto))
File "/usr/local/lib/x86_64-linux-gnu/python3.8/site-packages/paraview/servermanager.py", line 2761, in _createClassProperties
if (prop.GetInformationOnly() and propName != "TimestepValues" \
AttributeError: 'NoneType' object has no attribute 'GetInformationOnly'
- there are error messages already present when starting paraview:
gosia@nela:~$ paraview
( 0.944s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=ScalarFieldNormalizer were found.
( 1.036s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3b88d480): Could not create a proxy of group: filters type: ScalarFieldNormalizer
( 1.037s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=ScalarFieldNormalizer were found.
( 1.037s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3b88d480): Could not create a proxy of group: filters type: ScalarFieldNormalizer
( 1.038s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=SphereFromPoint were found.
( 1.038s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3b888430): Could not create a proxy of group: filters type: SphereFromPoint
( 1.043s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=ScalarFieldNormalizer were found.
( 1.043s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3ba04db0): Could not create a proxy of group: filters type: ScalarFieldNormalizer
( 1.044s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3ba04db0): Could not create a proxy of group: filters type: ScalarFieldNormalizer
( 1.106s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=ScalarFieldNormalizer were found.
( 1.107s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3abfaff0): Could not create a proxy of group: filters type: ScalarFieldNormalizer
( 1.107s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=ScalarFieldNormalizer were found.
( 1.108s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=SphereFromPoint were found.
( 1.108s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3b5711d0): Could not create a proxy of group: filters type: SphereFromPoint
( 1.110s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=ScalarFieldNormalizer were found.
( 1.111s) [paraview ]vtkSMDeserializerXML.cx:57 ERR| vtkSMCompoundProxyDefinitionLoader (0x558f3b4d6eb0): Could not create a proxy of group: filters type: ScalarFieldNormalizer
( 1.111s) [paraview ]vtkSIProxyDefinitionMan:525 ERR| vtkSIProxyDefinitionManager (0x558f38b9f4f0): No proxy that matches: group=filters and proxy=ScalarFieldNormalizer were found.
( 8.422s) [paraview ] vtkSMProxy.cxx:268 WARN| vtkSMCompoundSourceProxy (0x558f3b5acb60): Subproxy required for the exposed property is missing.No subproxy with name : TTKSphereFromPoint1
what can i do to solve this issue?
thank you for any suggestions!
