trame: add custom endpoint
For my trame-based application, I want to simply add an endpoint so that the user can get/post that endpoint url and get some computed value.
For example, if my server is running on localhost:8080, I want to register a callback so that if the user accesses localhost:8080/get_results, it’ll call a Python function which will return some custom results.
Any suggestions for doing that? thanks!
You can add new route endpoints by doing something similar to that.
HTH,
Seb
Hi VTK community,
I have a similar issue with trame binding a custome endpoint (eg: http://localhost:8080/home/) to trame app index page (http://localhost:8080). Is there a quick way to achieve this?
Best regards!
Jack Shen
I’m not sure to understand what you are asking? Are you wondering how to setup a reverse proxy (apache/nginx) or something else?
