trame: inject custom css
In a trame + paraview based application, all I want to do is inject this following css. How can I do that?
html {
  overflow-y: hidden
What’s happening is I am getting this y-scrollbar (highlighted below) and I want to get rid of it. Just adding this little snippet above using the browser’s developer tools panel does the trick.
You can use the trame.widgets.client.Style() to inject any CSS. That example perform dynamic update. But for your usecase, you can simply do the following
from trame.widgets import client
with xxx as layout:
   client.Style("html { overflow-y: hidden; }")
HTH,
Seb
Sweet. client.Style(...) did the trick. Thanks!
