trame: multiple renderers/renderWindow
Hi all,
I have some doubts about how to handle multiple view of the same file (in local rendering). For example, I wanted to have two different views of the same object side by side (organized with vuetify row/cols). I wrote this code:
camera_1 = vtkCamera()
camera_1.SetPosition(.........)
camera_1.SetFocalPoint(.........)
camera_1.SetViewUp(.........)
camera_1.SetParallelScale(.........)
camera_2 = vtkCamera()
camera_2.SetPosition(.........)
camera_2.SetFocalPoint(.........)
camera_2.SetViewUp(.........)
camera_2.SetParallelScale(.........)
ren_1 = vtkRenderer()
ren_1.SetActiveCamera(camera_1)
ren_2 = vtkRenderer()
ren_2.SetActiveCamera(camera_2)
renWin_1 = vtkRenderWindow()
renWin_1.AddRenderer(ren_1)
renWin_1.SetWindowName("First")
renWin_2 = vtkRenderWindow()
renWin_2.AddRenderer(ren_2)
renWin_2.SetWindowName("Second")
iren_1 = vtkRenderWindowInteractor()
iren_1.SetRenderWindow(renWin_1)
iren_2 = vtkRenderWindowInteractor()
iren_2.SetRenderWindow(renWin_2)
mapper = vtkDataSetMapper()
mapper.SetInputConnection(reader.GetOutputPort())
actor = vtkActor()
actor.SetMapper(mapper)
ren_1.AddActor(actor)
ren_2.AddActor(actor)
Then in trame definition:
with SinglePageWithDrawerLayout(server) as layout:
    layout.title.set_text("Test")
    with layout.content:
        with vuetify.VRow(classes="fill-height"):
            with vuetify.VCol(cols = 6):
                view = vtk.VtkLocalView(renWin_1)
                view = vtk.VtkLocalView(renWin_2)
But I obtain the same view in each one. Sometimes with the first camera position, sometimes with the second one (it seems to depend on the fact that I added some code, even unrelated to render definition. Strange behaviour…)
Is this the right way to manage this problem? Or am i doing something wrong?
Thanks
Local rendering currently has an issue with multiple views. Nothing too bad to fix it but I needs to find the time. Hopefully the holiday break will be enough.
I might have fixed it with trame-vtk==2.0.10. You can find that example that test and use multiple views.
Thank you Sebastien. I will look into in a few days
