Transform geometry based on input from a table of points
This topic appears quite often in the archives but I was not able to figure out how to do this, perhaps because I’m a total vtk/python noob.
I have a geometry file (think of the VTK cow for example) and a time series of csv files with the new centre of gravity and orientation angles. I convert the csv files to points (TableToPoints) and I am trying to use them as input for a filter to translate and rotate my geometry (cow).
The problems I have to solve are:
  • how to reference the TableToPoints inputs in the transformation of the cow. The python calculator requires that both datasets are equal if I want to use the input[0].* and input [1].* si I guess this is not the right method.
  • The transform filter through a python script is probably the way to go but I am at a loss how to reference the TableToPoin inputs. Animate polydata using programmable filter is close but the author takes a constant multiplied by the time in transform.RotateY(-5*t) and I would like see something like TableToPoints.PointData[“Pitch”]
  • ideally I would like to do the rotations and translations myself and simply update the coordinates of the geometry without going through the built in Transform functions, perhaps the programmable filter is the solution then. Is it possibly to simply use the inputs[0].Points[:,:] vector and rotate and translate it using custom transformations?
My test setpup looks like this:
the goal would be to make the box follow the DX,DY,LaserAltitude path and rotate with HEADING(Z), PITCH_ANGLE(Y) and ROLL_ANGLE(X).
The programmable filter approach seems to be the right one, you should be able to recover the point data as well.
I would appreciate a hint how to do it. My knowledge of programming in Paraview is unfortunately close to zero.
My base script would be this (taken from the wiki):
pdi = self.GetPolyDataInput()
pdo =  self.GetPolyDataOutput()
newPoints = vtk.vtkPoints()
numPoints = pdi.GetNumberOfPoints()
for i in range(0, numPoints):
    coord = pdi.GetPoint(i)
    x, y, z = coord[:3]
    x = x + 1
    y = y + 1
    z = z + 1
    newPoints.InsertPoint(i, x, y, z)
pdo.SetPoints(newPoints)
I can operate on the cube’s coordinates but I have no idea how to reference the TabletoToPoints point data in the script.
okay, some progress.
input0=inputs[1]
data0=input0.PointData["DX"]
data1=input0.PointData["DY"]
data2=input0.PointData["Laser_Altitude"]
print(data0,data1,data2)
    x, y, z = coord[:3]
    x = x + data0
    y = y + data1
    z = z + data2
I am able to reference the TableToPoints. What is missing is to force the filter to update with each new time step.
…I’m getting there :wink:
I managed to update the Programmable Filter, yuhuuu.
so I added the RequestInformation Script:
def setOutputTimesteps(algorithm , timesteps):
    "helper routine to set timestep information"
    executive = algorithm.GetExecutive()
    outInfo.Remove(executive.TIME_STEPS())
    for timestep in timesteps:
        outInfo.Append(executive.TIME_STEPS(), timestep)
    outInfo.Remove(executive.TIME_RANGE())
    outInfo.Append(executive.TIME_RANGE(), timesteps[0])
    outInfo.Append(executive.TIME_RANGE(), timesteps[-1])
setOutputTimesteps(self,(0,0))
and it works. It’s some Frankenstein filter which frankly speaking I do not understand but it does the job for now.
Just to finish this thread and close it. I achieved exactly what I wanted with the help of:
The key point is to avoid loops and use numpy dot product with broadcasting.
Programmable Filter
  1. Select geometry and Ctrl+TabletoPoints
    TableToPoints should have Keep All Data Arrays ticked
  2. Script
import numpy
#get cog and angles from the cvs file (TableToPoints)
input1=inputs[1]
x_cg=input1.PointData["DX"]
y_cg=input1.PointData["DY"]
z_cg=input1.PointData["Radar_Altitude"]
yaw=float(-input1.PointData["HEADING"]*numpy.pi/180)
pitch=float(input1.PointData["PITCH_ANGLE"]*numpy.pi/180)
roll=float(-input1.PointData["ROLL_ANGLE"]*numpy.pi/180)
#initiliase the geometry class
#initialise time (file number actually)
ts= outInfo.Get(executive.UPDATE_TIME_STEP())
t=float(ts)
# from body to inertial frame
R = numpy.array([ [cos(yaw)*cos(pitch),cos(yaw)*sin(roll)*sin(pitch)-cos(roll)*sin(yaw),sin(roll)*sin(yaw)+cos(roll)*cos(yaw)*sin(pitch)] , [cos(pitch)*sin(yaw),cos(roll)*cos(yaw)+sin(roll)*sin(pitch)*sin(yaw),cos(roll)*sin(pitch)*sin(yaw)-cos(yaw)*sin(roll)] , [-sin(pitch),cos(pitch)*sin(roll),cos(roll)*cos(pitch)] ])
output.Points = R.dot(inputs[0].Points.T).T
output.Points = (output.Points.T+[x_cg,y_cg,z_cg+1.795]).T
  1. RequestInformation Script
