I want to Pan/Translate the current view along a direction (or move the center of the view to some other location)
Basically, I am want exactly the same results as panning with mouse but in more controlled manner. (Move along X-axis but not Y/Z-axis)
Any suggestions?
I have tried using “Adjust Camera” options, but it’s not doing what I expected.
Thanks.
mwestphal
(Mathieu Westphal (Kitware))
March 5, 2020, 2:36am
2
Just pan with the mouse while having this window open to see how to do it.
You need to change position and focal point correctly.
Yep. I had to change focal point along with the position and it worked.
I thought changing just the position along a fixed plane parallel to axis would not require focal point change.
Thanks!
