I wish to transform (translate and rotate) a 2D image (geotiff) using the “Transforming” settings in the image’s properties. Rotation along the X-axis works well, however rotating along the Y axis results in a rotation along the Z axis. I attached a screen capture. The last transformation I need would tilt the image along y-axis, so it becomes parallel to the the black line.
Thank you!
