Trouble loading DICe-generated Exodus (.e) file in ParaView (only works in 5.9.1)
Greetings everyone,
I’ve been trying to load an Exodus (.e) file generated from DICe (Digital Image Correlation Engine) into ParaView, but I haven’t had any luck with recent versions. So far, only ParaView 5.9.1 has been able to load the file successfully.
Has anyone encountered a similar issue or found a workaround that works with newer versions of ParaView?
I’d greatly appreciate any insights.
Thanks in advance,
Mahesh
Please share your data.
