Error_log_20200607.txt (31.1 KB)
I am attempting to load in data from a CSV file into Paraview and view it using a TableToStructuredGrid filter but am having some problems. The data in my CSV file has the following header row (separated by commas): X, Y, Z, Distance, B_X, B_Y, B_Z, B_Magnitude. It contains cartesian points (X,Y,Z) and the components of the magnetic field vector at each point (B_X, B_Y, B_Z), along with the total magnetic field magnitude (B_Magnitude). The CSV file contains 2,413,800 rows of data represents 149 units in the radial direction, 90 units in the Theta direction, and 180 units in the Phi direction (14990180 = 2,413,800).
I am able to successfully open the CSV file in ParaView and see the data in Spreadsheet view. When I initially open the CSV file, I choose the option for “CSV Reader”. There is also an option for “GDAL Vector Reader” but if I choose that option, then I get an error message immediately upon opening the file. After selecting “CSV Reader” and clicking “Apply” in the Properties panel, I then add in a “TableToStructuredGrid” filter. In the Properties panel for this filter, I select 0 and 1 as the lower/upper bounds for each of the 3 Extents in the Whole Extent section, and I then select the X Column, Y Column ,and Z Column, as X, Y, and Z, respectively. When I then click on Apply for the filter, I get an Error message, which I have included as an attachment here. One of the main error messages that keeps recurring states that the input table must have exactly 8 rows, whereas my table has 2,413,800 rows. I am not sure why the input table is only allowed to have 8 rows.
Note also that my original dataset is stored in a .FITS file and I converted and saved it into a CSV format because that is the method I am familiar with for leading files into ParaView. Ultimately, I would like for ParaView to be able to recognize B_X, B_Y, and B_Z and the components of the magnetic field vector and be able to show streamlines in Render View.
Can someone please help me understand what I am doing wrong here. I have read through the ParaView Tutorial and Guide, but don’t see much information to assist with loading in data. If there are any helpful resources I should look at, please let me know. Thanks very much
