Trouble Running ParaView 5.13.3 on HPC Cluster: Missing libGL.so.1 and libglapi.so.0
Hi all,
I’m trying to install and run ParaView 5.13.3 on a Linux-based HPC system (Stanford’s Sherlock cluster), but I’m running into some shared library issues. I’ve tested both:
  • The standard MPI Linux build: ParaView-5.13.3-MPI-Linux-Python3.10-x86_64
  • The OSMesa (headless) build: ParaView-5.13.3-osmesa-MPI-Linux-Python3.10-x86_64
When I run pvpython from either installation, I get errors like the following:
error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
Or, for the OSMesa version:
error while loading shared libraries: libglapi.so.0: cannot open shared object file: No such file or directory
Running ldd on pvpython-real confirms that these shared objects are missing. I tried loading system modules like libglvnd, xorg, and mesa, but no luck so far.
Is there a way to run the OSMesa version of ParaView fully headless on a CPU-only HPC cluster without needing libGL.so.1?
I’m mainly interested in using pvpython for batch visualization and post-processing in an automated pipeline (no GUI).
Thanks in advance for your help!
libglapi.so.0 is provided in the binary package of the headless version:
ParaView-5.13.3-osmesa-MPI-Linux-Python3.10-x86_64/lib/mesa/libglapi.so
But for some reason the rpath was not set correctly. You can work around this issue with:
LD_PRELOAD=./lib/mesa/libglapi.so ./bin/pvserver-real
./bin/pvserver --mesa is the “intended” mechanism.
I’m a bit confused now, if we always need it with osmesa binary, why do we rely on the one from the system by default ?
Hmm. We shouldn’t need OSMesa until the class(es) that use it are instantiated. Could be an unforeseen change from the backend change. @jaswantp?
This doesnt concern the backend change, because this concerns only the release released before the backend change.
