I have a python script that is supposed to do a box clip on a volume rendered image, but the clipping seems wrong and I’m not sure how to fix it.
I copied my code into ParaView and ran it in the Python shell and it gets me this:
which is not what I wanted. However, viewing the properties panel (and hence showing the box) fixed the problem:
but since I’m running the script using pvpython i.e. without the GUI, there is no way I could write a line of code that “opens the properties panel” (tracing in ParaView showed nothing).
It also seems that the faulty clip is only clipping a quarter of the box (top-right). Is this a bug, or is there any way I can fix this?
I’m running on ParaView 5.6.0 64-bit. Here’s part of the code that does the clipping:
from paraview.simple import *
import numpy as npdisable automatic camera reset on ‘Show’
Define global variables
Ro = 22.25/1000.0
Ri = 17.46/1000.0
L = 1000/1000.0
ecc = 46./100.0
delta = -(Ro-Ri)*ecc # delta is a negative valuecreate a new ‘OpenFOAMReader’
case3foam = OpenFOAMReader(FileName=‘/home/etrati/Documents/OpenFOAM/newtonian/case2/case2.foam’)
case3foam.CaseType = ‘Reconstructed Case’
case3foam.LabelSize = ‘32-bit’
case3foam.ScalarSize = ‘64-bit (DP)’
case3foam.Createcelltopointfiltereddata = 1
case3foam.Adddimensionalunitstoarraynames = 0
case3foam.MeshRegions = [‘internalMesh’]
case3foam.CellArrays = [‘alpha.heavy’]
case3foam.PointArrays = [‘alpha.heavy’]
case3foam.LagrangianArrays =
case3foam.Cachemesh = 1
case3foam.Decomposepolyhedra = 1
case3foam.ListtimestepsaccordingtocontrolDict = 0
case3foam.Lagrangianpositionswithoutextradata = 1
case3foam.Readzones = 0
case3foam.Copydatatocellzones = 0get active source.
case3foam is the file that we want to load
case3foam = GetActiveSource()
set active source
SetActiveSource(case3foam)
get active view
renderView1 = GetActiveViewOrCreate(‘RenderView’)
Properties modified on renderView1
renderView1.CameraParallelProjection = 1
show data in view
case3foamDisplay = Show(case3foam, renderView1)
get active source.
openFOAMReader1 = GetActiveSource()
get display properties
openFOAMReader1Display = GetDisplayProperties(openFOAMReader1, view=renderView1)
set scalar coloring
ColorBy(openFOAMReader1Display, (‘CELLS’, ‘alpha.heavy’))
rescale color and/or opacity maps used to include current data range
openFOAMReader1Display.RescaleTransferFunctionToDataRange(True, False)
show color bar/color legend
openFOAMReader1Display.SetScalarBarVisibility(renderView1, True)
get color transfer function/color map for ‘alphaheavy’
alphaheavyLUT = GetColorTransferFunction(‘alphaheavy’)
get opacity transfer function/opacity map for ‘alphaheavy’
alphaheavyPWF = GetOpacityTransferFunction(‘alphaheavy’)
change representation type
openFOAMReader1Display.SetRepresentationType(‘Volume’)
create a new ‘Clip’
clip1 = Clip(Input=openFOAMReader1)
get animation scene
animationScene1 = GetAnimationScene()
update animation scene based on data timesteps
animationScene1.UpdateAnimationUsingDataTimeSteps()
toggle 3D widget visibility (only when running from the GUI)
Show3DWidgets(proxy=clip1.ClipType)
Properties modified on clip1
clip1.ClipType = ‘Box’
clip1.Invert = 0Define variables for clipping
xpos = 0
xscale = 1
ypos = delta - Ri
yscale = 2*Ri/RoProperties modified on clip1.ClipType
clip1.ClipType.Position = [xpos, ypos, 0.0]
clip1.ClipType.Scale = [xscale, yscale, 1.0]show data in view
clip1Display = Show(clip1, renderView1)
Properties modified on openFOAMReader1
openFOAMReader1.MeshRegions = [‘internalMesh’]
openFOAMReader1.CellArrays = [‘alpha.heavy’]update the view to ensure updated data information
renderView1.Update()
clip1Display.SetRepresentationType(‘Volume’)
hide data in view
Hide(openFOAMReader1, renderView1)
Thanks in advance!
