Unable to display 3D data in HDF5 format
sample_3d_data.h5 (978.6 KB)
gene_h5.py (1.6 KB)
I cannot display 3D data in HDF5 format (sample_3d_data.h5) in paraview. This data was generated using the attached sample python program (sample_3d_data.h5).
The error displayed is as follows. Do you know how to resolve this error?
ERROR: In vtkPDALReader.cxx, line 87 vtkPDALReader (0000019EAA271840): Cannot open file C:\Users\70491295\Desktop\homcloud\sample_3d_data.h5 ERROR: In vtkExecutive.cxx, line 730 vtkPVCompositeDataPipeline (0000019E96471A40): Algorithm vtkPDALReader (0000019EAA271840) returned failure for request: vtkInformation (0000019EAD267150) Debug: Off Modified Time: 2875060 Reference count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 FROM_OUTPUT_PORT: 0
HDF5 is not a format, its a container, which format are you using ?
reading the code, it looks like a simple 3D blob of data, you will need to read that using your own reader that you could write in a python programmable source.
