I have been trying to view my Paraview scene on an Oculus. While I can scale and translate the world with the controllers, I have been unable use the joystick to fly around as described in this blog post, specifically this portion:
Pressing down on the touch-pad or joystick will start flying in the direction the controller is pointing.
For the Occulus, moving the joystick on the right controller up or down (not pressing) should fly you forward or backwards in the direction the controller is pointing. I just checked and it was working. I started steam first before sending PV to VR.
I tried opening a state file I had in the executable you gave, but was met with the error: “No proxy that matches: group=filters and proxy=ProgrammableFilter were found.” I received a similar error for Programmable Source.
Unfortunately my builds do not include python (which those filters require). Apparently there is some challenge in redistributing python and I never dug into it.
