Hello, I’m a relatively new user which until now has only ever dealt with native VTK files. I’ve now started using a solver which only outputs Tecplot binary .plt files, but I’ve been unable to open them with Paraview.
More specifically Paraview is able to open the file, but crashes instantly when trying to load the data.
Here is an example of the file I’m trying to read.
fld.000001.plt (2.6 MB)
I’m fairly certain that the data is not corrupt as the Tecplot reader can open it without any problems. I’ve even tried converting it into a .dat file through Tecplot, but in that case the opened data becomes jumbled and the terminal gives off an error of being unable to recognize a data point:
“ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\Geometry\vtkTecplotReader.cxx, line 2177
vtkTecplotReader (00000231CC6FA050): \wsl.localhost\Ubuntu-22.04\home\franmen\code\test_m13\Out\fld.1.dat: The record type -6.857131977E-02 found in the file is unknown.”
I’m using Paraview 5.10.1 on Windows if it is of any help.
Thank you in advance
